Mystery part?
Location: We Cant Stop Here This Is Bat Country, So CaL, USDM
Re: Mystery part? (NineTwoSi)
depending on the year of the Y8, it might be part of the air injection system, when I put a Y8 manifold on my Y7 I had to block the air injection ports....unless you enjoy a 3K RPM idle. if it's not that, then it's a fuel rail from a much older honda, hard to tell from the picture.
Re: Mystery part? (2000psi)
THe d16y8 has an air injection system? you mean on the exhaust side?
It does seem to have holes for fuel injectors, but looks flat, so I don't think it is a fuel rail. It looks like the lower mount for the injector that bolts onto the head, but the d16y7 and d16y8 both have this part built into the intake manifold. I s'pose it was a mistake and from a much earlier (or different) honda engine.
Re: Mystery part? (masterexpert)
It holds the Lost Motion Assemblies for the y8. If you take off the valve cover, this piece rests on top of the rocker assembly. Here:
http://slhondaparts.com/browse...=true
Part #5
Part #5
I think the 99-00 Y8's had the air injection....it's on the intake side not exhaust, there is a port into each runner on the IM. It might also only be a California add on, as Honda has to jump through alot of hoops to sell us CA guys a car....THANKS EPA!!!
99-00 y8 had air injection. And that part is on top of the rocker assembly and has nothing to do with the air injection or intake manifold or fuel rail.
marcus029
03-06-2008 07:08 AM
unsungsohc
07-11-2004 11:27 PM
pornstarSR
08-06-2003 09:01 PM
