mysterious anti freeze
my car has an abnormal idle.it will go from about 400 rpm to 1200 then keep in that cycle.the timing is perfect,it has a new distributor,new plugs,new fuel filter,and a new iac valve.it is running wierd and the engine studders when heavy on the gas or at low rpm's. i bought a new iac valve and i was taking the vacuum hoses off the bottom and anti-freeze came out.im not a mechanic im a body man.is there supposed to be anti freeze in those lines or am i in trouble.if so i appreciate any help in solving the problem
Re: mysterious anti freeze (packthis)
where would i get the piece of heater system for the throttle body,and how much would it run me? thanks for the reply
I definitly recommend taking all that off and cleaning it. All the stuff off the Intake mani around the TB, I had some problems so i took mine apart and cleaned it, corroded like crazy, and it idled much better afterwards.
Re: mysterious anti freeze (Sandmaggot)
i put on the new iac vavle that i ordered and there was no change in the idle or anything.then i put the stock one back on and still the same thing.before i put it back on i cleaned it out with carb cleaner.i dont kno what else to do.except a motor change.haha.
wondersparrow
05-10-2008 05:41 PM
smash fascism
04-10-2005 06:39 AM
