My WTF? car wont start question
Ok cliff notes version, intake manifold had a leak, car was in running shape when i took it off, fixed it reinstalled it, when connecting the battery i let the wrench ground out for a second by accident.
Went to start the car-fuel pump primed and everything looked fine, tuned key just got the clicks (you know the clicks). Disconnected the battery and tried again now the fuel pump isnt even priming. I checked the fuses. WTF am i missing?
Re: My WTF? car wont start question (b20vtecEK)
is the battery dead? Did you short it out when you grouned it? I would start there. Does your horn work?
Re: My WTF? car wont start question (underpressure02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underpressure02 »</TD></TR><TR><TD CLASS="quote">is the battery dead? Did you short it out when you grouned it? I would start there. Does your horn work?</TD></TR></TABLE>
batteries not dead i tried to jump it to make sure still didnt work, i did start there i checked all the fue box and under that dash, yes the horn works
did you check to see if your getting spark before the fuel pump quick working? i would also check the fuel pump relay you could have shorted that out. if no spark then i would check the normal dist, cap, rotor. also did you make sure to reconnect the tps and all vacum lines to tb and manifold
Re: My WTF? car wont start question (Hatch'd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch’d »</TD></TR><TR><TD CLASS="quote">did you check to see if your getting spark before the fuel pump quick working? i would also check the fuel pump relay you could have shorted that out. if no spark then i would check the normal dist, cap, rotor. also did you make sure to reconnect the tps and all vacum lines to tb and manifold</TD></TR></TABLE>
yes i had spark, the motor ran, now it doesnt
The battery may be low on juice. The horn/lights/radio and stuff may work, but the starter doesn't neccesarily get enough power. The starter requires the most power out of anything else on the car. The clicking noise is your starter attempting to turn the engine over. But if you're not cranking over, then it's either that you don't have enough power to the starter to do so (bad starter, bad battery) or your engine is seized and can't be turned over.
Re: (yinlun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yinlun »</TD></TR><TR><TD CLASS="quote">The battery may be low on juice. The horn/lights/radio and stuff may work, but the starter doesn't neccesarily get enough power. The starter requires the most power out of anything else on the car. The clicking noise is your starter attempting to turn the engine over. But if you're not cranking over, then it's either that you don't have enough power to the starter to do so (bad starter, bad battery) or your engine is seized and can't be turned over.</TD></TR></TABLE>
I hooked up my truck to it with jumper cables, still nothing, and the car ran yesterday and now it doesnt so its no siezed.
WTB AUTO EK
07-05-2005 11:05 AM
julsal
10-25-2004 06:00 PM
