My Weekend Rear Main Seal Adventure!
Old 04-25-2004, 08:45 PM
Risky Business
BauleyCivic's Avatar
Default My Weekend Rear Main Seal Adventure!
Yeah, so there really isn't a point to this thread but i've had a long weekend and i figure i'd share what I was doing. My transmission was leaking oil from the flywheel cover. The general consensus was rear main seal, but other possibilities were axle seals and oil pan gasket. Last weekend I replaced the axle seals and oil pan gasket, but yet the leak was still there...so this weekend...it was party time with the rear main seal
Transmission, clutch, flywheel all off...about 5 hours worth of work
My driveway was a mess...I was checking the input shaft seal in the tranny to make sure that wasnt the problem...and it wasnt...so all of this for nothing
Bad Rear main seal
mmmmmm oil
Oil + Clutch = hotspots! (this flywheel was newly resurfaced 2 weeks ago )
The clutch housing side of the transmission was COVERED in oil...even worse than the block side. But 6 cans of brake cleaner later, and everything is good. Didn't finish tonight, but hopefully the bitch will be running sometime later this week. And i'll even have some pics of the two slave cylinders I broke!!!
Hope you all had a better weekend than I did...holla
Old 04-25-2004, 08:47 PM
Ricey McRicerton's Avatar
Default Re: My Weekend Rear Main Seal Adventure! (BauleyCivic)
Damn Dustin. I wish I could have been there to help out and get you up and running quicker.
Old 04-25-2004, 08:49 PM
dantastic's Avatar
didnt change the rear main seal when u had the flywheel resurfaced 2 weeks ago?
i didnt have a weekend to waste, so i had to pay $300 for someone to put in my clutch and replace my rear main at the same time
Old 04-25-2004, 08:52 PM
NA95d16z6's Avatar
sorry to hear about that dustin. was the clutch all glazed over like i thought? if you got a pic of the clutch id like to see. sorry to hear. good luck. keep us up to date. hopefully youll be able to get back in the 15's
SOHC_MShue's Avatar
damn hope you fix this soon man .
Old 04-25-2004, 08:57 PM
smnowell's Avatar
Default Re: My Weekend Rear Main Seal Adventure! (SOHC_MShue)
HAHAHAHA, Dustin, your car sucks. It's because D-series motors are the worst evAr!! Hopefully we can get this piece of **** running again tomorrow night after a long day of class/work...
Old 04-26-2004, 07:08 AM
Risky Business
Default Re: My Weekend Rear Main Seal Adventure! (b16a ferio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic &raquo;</TD></TR><TR><TD CLASS="quote">didnt change the rear main seal when u had the flywheel resurfaced 2 weeks ago?
Heh yeah. I did read though that overtorqued flywheels can cause bad rear main seals, so that might have been a problem but who knows.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a ferio &raquo;</TD></TR><TR><TD CLASS="quote">HAHAHAHA, Dustin, your car sucks. It's because D-series motors are the worst evAr!! Hopefully we can get this piece of **** running again tomorrow night after a long day of class/work...</TD></TR></TABLE>
Yeah we'll see...slave cylinder being attached with one bolt owns!
Old 04-26-2004, 07:13 AM
degooser's Avatar
sorry that sucks...
now you can do a rear main seal write up since ur already down there..
Old 04-26-2004, 07:59 AM
Caveman74's Avatar
My bro just had his clutch replaced on his VW Corrado and the shop didnt put the main seal in correctly. It leaked and screwed flywheel and his sachs clutch
Old 04-26-2004, 08:05 AM
Unceasing Measure
Archidictus's Avatar
You didn't have anyone to work with? Awwww .
Old 04-26-2004, 08:17 AM
TurboBumblBee's Avatar
Default Re: (Archidictus)
i just replaced went through the same repairs you did 2 weeks ago.. main seal, axle seals, and oil pan gasket.. let me tell you, its a dirty job but i was sick of seeing oil underneath my car whenever i backed out of a parking spot.. same weekend i replaced the clutch and flywheel on my friends integra gsr so i had a lotta fun layin on the garage floor that weekend...
Old 04-26-2004, 09:27 AM
Pikachu's Avatar
My oil's leaking from somewhere as well. I dunno where it's coming from though. I think it's my oil pan gasket so I'm gonna have that replaced this weekend. While I was at meineke, the guys there said it was the rear main seal possibly. Is there a way to tell if it's the oil pan gasket or the rear main seal?
Old 04-26-2004, 10:03 AM
Default Re: (Pikachu)
no not really....
start with simple then go down the road still its fixed
Old 04-26-2004, 10:10 AM
137's Avatar
Default Re: My Weekend Rear Main Seal Adventure! (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">Damn Dustin. I wish I could have been there to help out and get you up and running quicker. </TD></TR></TABLE>
you're a bad friend
I know what you mean about having a bad main seal, mine went to **** and caused all my oil to leak out under hard driving and told my bearing on number 2 to eat a fat one.
Engine siezed after the bearing snapped in two.
Old 04-26-2004, 10:43 AM
Risky Business
Default Re: My Weekend Rear Main Seal Adventure! (137)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 137 &raquo;</TD></TR><TR><TD CLASS="quote">
Engine siezed after the bearing snapped in two. </TD></TR></TABLE>
glad I replaced mine
Old 04-26-2004, 11:10 AM
Pikachu's Avatar
Hey BauleyCivic, is there a way to tell whether it's the oil pan gasket or the rear main seal?
Old 04-26-2004, 11:19 AM
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pikachu &raquo;</TD></TR><TR><TD CLASS="quote">Hey BauleyCivic, is there a way to tell whether it's the oil pan gasket or the rear main seal?</TD></TR></TABLE>
Do what I did. Replace the oil pan gasket, if it still leaks, replace the rear main seal.
Old 04-26-2004, 11:39 AM
cxSHOE's Avatar
Default Re: (BauleyCivic)
damn bauley,
might as well make this into a writeup...hint hint hint...
Old 04-26-2004, 11:41 AM
Risky Business
Default Re: (cxSHOE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxSHOE &raquo;</TD></TR><TR><TD CLASS="quote">damn bauley,
might as well make this into a writeup...hint hint hint...</TD></TR></TABLE>
Haha, nah. I figure i'd post this and then if anyone has questions i can help. But this is not going to be a writeup...too long and its just general maintenance that you can find in the helms.
Old 04-27-2004, 04:17 AM
xenocron's Avatar
Is replacing the Rear Main Seal "General Maintenance" as you put it when replacing Clutch/Flywheel? ...like replacing the water pump when doing your timing belt because you have it all apart?
Old 04-27-2004, 05:03 AM
Global Moderator
Jimmy's Avatar
you get props from me for doing this by yourself.
Old 04-27-2004, 05:07 AM
ABK
ABK's Avatar
put your car on the jacks and strart it up, you should see where it's leaking from.
Old 04-29-2004, 05:37 AM
Suspetise...
Stinkycheezmonky's Avatar
Default Re: (ABK)
My Hype R may be burning oil, but at least it's running, fool.
Old 04-29-2004, 06:06 AM
CHONCH's Avatar
bauley - once the tranny & flywheel are off, do you have to remove any other stuff to replace that seal? or does it just pop out?
i have a tiny leak from my car, and i suspect that it is the seal.
Old 04-29-2004, 07:24 AM
B_CRUZ!'s Avatar
you get big props from me for DIY.
Quick Reply: My Weekend Rear Main Seal Adventure!
