my valves are ticking pretty loud - will this affect engine performance?
Old 03-27-2011, 08:43 AM
allums34's Avatar
Default my valves are ticking pretty loud - will this affect engine performance?
i have a b16 motor with skunk2 cams, hondata s100, 310 rc injectors, bisimoto headers my question is my valves are ticking pretty loud will this affect engine performance.
Old 03-27-2011, 08:57 AM
Red_Army's Avatar
Default Re: vtec
valvejob. and yes it will.
Old 03-27-2011, 09:11 AM
The Grumpiest
grumblemarc's Avatar
Default Re: vtec
What does that have to do with VTEC? Maybe you should make your title more descriptive.
Old 03-27-2011, 09:14 AM
Former User's Avatar
Default Re: vtec
^Thank you.
OP, seriously work on creating informative thread titles - edited.
Old 03-27-2011, 10:47 AM
allums34's Avatar
Default Re: my valves are ticking pretty loud - will this affect engine performance?
because when vtec engages i get a misfire but out only when vtec engages i would have to slow down and let the rpm drop to around two thousand rpms so i can continue driving. and when i do let the rpm drop i hear a clicking noise inside the heads near the vtec solenoid
Old 03-27-2011, 10:50 AM
The Grumpiest
Is this a continuation of this issue?
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/misfire-2888511/
And this one?
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/93-civic-b16-swap-misfire-codes-1-3-7-14-21-22-a-2883710/
Also you have a habit of starting posts and not answering questions looking at all your previous posts. You never answered a lot of the previous questions put to you.
Old 03-27-2011, 10:55 AM
allums34's Avatar
yes it is
Old 03-27-2011, 10:57 AM
The Grumpiest
That's what I thought. Maybe if you would answer some of the questions asked of you before you wouldn't be going on a third month of these problems.
Originally Posted by allums34
yes it is
So what are your answers to all the past questions? Before asking anymore questions, address those first.
Old 03-27-2011, 11:13 AM
The Grumpiest
i hope some one out there can help me if not i am quitting the game and buying a truck. I have a 93 honda civic with a b16 motor. I have bisimoto header, skunk2 stage one cams, aem short intake, and apex exhaust, rc310 injectors, and s100 hondata. my problems misfire when vtec engage, run very rich, idles at 2000 rpm and on take off its feels like its bucking. this is what i have tried new distributor, change map o2 tps coolant temp. sensor, had the whole engine harness remove and had all wires soldier together that was twisted or broken, and had the chip removed. Still have the same problems runs even worse and now i got six engine codes 1, 3, 7, 14, 21, 22. i will not put the shop on blast but if they cant fix it on friday i will. so help
can anyone tell me why my car wont start with a stock ecu. i had a chip ecu with s100 hondata but someone stole out of my car so i got a stock ecu for my car check engine come on right away and does not turn off i cant even get a code from it by the the ecu is p28 and i have b16 with basic bolt on nothing major
Does the car start or not? Are you running a stock ECU or the chipped one? If stock why are you running a stock ECU with these mods? Was the Hondata stolen or not? Too many different stories here. Another post says you have major wiring issues.
My head is numb.
Old 03-27-2011, 11:43 AM
allums34's Avatar
ok this what i have done took it to inline four in garden grove california to have it rewired.,change distributor, spark plugs and wires fuel filter, fpr, map, tps, o2 sensor, check timing with gun and to see if it was tdc. the car runs good except when vtec engages. everytime people drive my car they say what the hell i never seen that before so i am open to suggetions
Old 03-27-2011, 01:23 PM
The Grumpiest
You don't have good reading comprehension. Why you choose NOT to answer questions is beyond me. Good luck getting it fixed.
Old 03-27-2011, 01:34 PM
ColorblindBass's Avatar
That's gonna be one mighty big repair bill if they actually fix all your problems.
Assuming you actually have those problems, with the amount of potential help and advice you've been offered and ignored, I'm starting to think your car is fine, and you just like to complain.
That's it! Don't worry about it guys, his car's fine. If it was actually in need of fixing, he would be cooperating.
Old 03-27-2011, 02:33 PM
Master Detailer
98civdx's Avatar
Do yu still have all of the check engine lights??
Do you still have the hondata ecu?
Now on the ticking. Have you adjusted the valves? it could also be the LMA's.
Old 03-27-2011, 06:06 PM
allums34's Avatar
ok i took out the hondata now i have p30 in it i do have engine light on code#14 so i clean the iacv still has light on this frriday i will have the valves look at. i know i have gotten a lot of good advice just fustrated that i tried so many advice nothing work. i paid in line four 650 dollars to fix the problem and all they did was to do me dirty. they claimed the rewired the engine harness, gave me a new program because my ecu was going into limp mode adjust my timing and clean the iacv. now i to pay a lawyer to get my money back from them so i am listening to you guys but just stress out thanks
Old 03-27-2011, 06:26 PM
Master Detailer
98civdx's Avatar
Your posts are pretty hard to read, try spacing things out. I am having to read it mulitiple times just to try and figure out what your saying.
Did you clear the ECU after cleaning the IACV?
What exactly did inline four do? What did they re-wire?
Cars can be difficult, and a Honda can be a bitch to figure out. They are either your best friend or your enemy. it may take a while to figure this out, hell, I am having issues with my car right this second.
Old 03-28-2011, 11:59 AM
Red_Army's Avatar
doubt you'll get your money back from I4. but you can try.
i doubt you've done any of the things you've been told since you haven't even answered the things you were asked. get one single post calm straight story so we can find out just where exactly you are.
Old 04-05-2011, 04:52 PM
allums34's Avatar
finally found the freakin problem bent valves. all the money i spent on rewiring the engine harness, different distributors, ecu, so many other things i could have bought a k motor set up.
thecorey
09-26-2009 04:58 PM
T-78RX7
09-03-2005 12:19 PM
whatcivic
06-06-2003 07:13 AM
MysticAzn03
08-30-2002 09:18 AM
tub_sephiroth
05-28-2002 10:25 PM
Quick Reply: my valves are ticking pretty loud - will this affect engine performance?
