My Ride, pretty sweet huh?
Guest
Posts: n/a
Hi everyone, my name is Di'Qwan, and i drive a blown 92 civic hatch-back. i got some decent mods on it, just wanted to share with my fellow civic enthusiasts. here are some of my mods, I got a Romulan Warbird engine swap, comes with 125hp right out of the crate, i also got a warpdrive double impact cannon intake fuel system regulator with a vavletrain quazi-connetics system, a cybernetic core built right in the engine, my CPU is a neural-net processor, a learning computer with biotechnology software, my warp factor is about 299018 MHK and 89056111.13488 YTRS, I got Photon torpedoes installed near the headlights and a dilithium charged intake manifold with a NO2 nitrous setup from Dragonclaw Racing, i got highly-polished eurathane bussard collectors and stainless steel bussard collector tips for that high speed road rage setup Quasiscience hooked me up with a hyperdrive baryon sweep system for inside my catalytic converters, ive beaten an enzo from 75-92 MPH in first gear, thats IMPORTS FOR YOU!!.. the small block V8s cant even touch this civic and is rear trans-axle is top of the line. Ive got a 7 speed automatic-manual transmission (very rare swap) and i got the 900 hp big-block V4 engine. ive got custom ground tripple cam-shafts, ported and polished copper head outter bore .008 cylinder head walls. I got dual crankshafts and a titanium alloy oilpan imported from Japan, my uncle lives there (hes chinese). Ive got a throttle body thats been drilled out to 200 MM. I got dual air intake systems that pertrude out of the hood. I got an intake manifold that actually turns red after he hits Vtec (i know what your thinking, Civic with vetec??) DAMN RIGHT. I got hi-flow AKI sports oil-pressure regulator simulator. Running elephant ton injectors. Also, Rubbing alcohol injection turbulator, all specially imported. Thats just for now, ill update you guys later on the mods, well cya later and happy v8 hunting!
