My new motor keeps dying
since i put the new motor in it idles high and also when i go to rev it it just dies out, and almost stalls. and when i go down the road i have to rev it really high and ride the clutch to move it at all. i have no i clue what it could be. someone help.
The Grumpiest
Re: My new motor keeps dying
Timing. Did you check it?
BTW, what car are we even talking about? What engine?
Maybe you need to cough up more details if you want decent advice.
no i did not check timing and i changed the idle air control valve and its running alot better . woud ineed to get it tuned for it to run right?
The Grumpiest
YOu need to check the timing.
Is the check engine light on?
If you're going to only answer every other question this is going to take a long time.
The only thing "wrong" that we know about is your thread. You haven't given us ANY relevant information, and you expect us to miraculously tell you what's wrong. You need to give us ALL relevant information. FULL engine code, head code, any work done, ECU being used, CELs, wiring harness being used, chassis it's in, as well as anything else that might be relevant.
You can't just say "I have a D15 and it isn't running right, what's wrong?" We aren't mind readers, and we aren't magicians.
i just replaced the motor. when i did that i but my old intake manifold on it replaced my tps and the check engine light comes on ofter it idles like a tractor for a little. i blocked off what i think is my iac valve and that makes the check engine light come on, after it comes on it idles fine and each time i turn on the car the code resets.
I gave you a very short list of things you need to tell us, and you answered exactly ZERO of those queries. If you aren't willing to tell us those things, do everyone who is trying to help you a favor and just stop posting. If you aren't capable of posting those things, tell us why you aren't capable and we can try to fix that problem.
There used to be a time when threads like this got locked with a quickness
fAyJai510
08-06-2011 12:03 AM
