My master cylinder is done!
Does anyone know how much a master cylinder would cost for a 94 ex? I need one badly my brakes suck. Tried everything new performance rotors new pads bled all brakes it's the only thing i can think of that can be wrong? Any ideas of what else?
Re: My master cylinder is done!
Make sure it is really caput, either leaking or physically broken or clogged. I personally can never get bleeding right and just let someone else deal with my hydro systems but I have done it and needless to say its kind of a B. Best of luck.
post us your brake problems. Sounds like you are guessing and throwing parts at it. However it is actully very easy to to if you do come to it. You just gotta have proper tools
If the seals in the master cylinder are bad, your brake pedal will slowly sink to the floor when you apply pressure. However, as long as you maintain pressure, the car will still stop fine.
the problem im having is that when i apply pressure to the brakes they go all the way to the floor. My car still slows down i just have to pump my brakes so they wont go all the way down. if i have steady pressure on the pedal it just keeps going down
Call some local auto parts stores to compare prices. Many will come with a lifetime warranty.
Wdpfreak145
06-14-2010 11:22 PM
