my list, need some help
hey i have a del sol S, and am swaping a jdm b18c1 motor into it.
so far i have:
Place Racing mounts
Place Racing Axels
Place Racing Shift Linkage
all i need now is my wiring harness, this is my problem, i have a del sol S so their is no vtec, so can i use my wiring harness with some modifications? or do i need to get a new one? what are some things you have used or have heard used for a similar swap.
so far i have:
Place Racing mounts
Place Racing Axels
Re: my list, need some help (b18csol)
nope just use the one you have and add vtec and knock. some modifications will have to be made.. simple and easy mods.. some sensors are located on different areas of the engine so all you need to do is put your harness against the new motor and see which clips need to be made longer. most honda harness wires are long enough just carefully cut back the tape down the harness and relocated the clip and just retape the harness when you're done.
you can make your own piggy back harness from clips taken from your new motor or tap your wires into the harness.. or just get ghetto and have loose wires everywhere.
good luck
good luck
1991crx16
10-18-2011 01:50 PM
