My fuckin new tailights are messed up. I need help
My ****** new tailights are messed up. I need help
I put in some new tailights for my car. Whenever I press on the brake and have a turn signal on. The turn signal turns off and the two guage cluster left and right signal lights light up.
In fact whenever my foot is on the brake the two guage turns signals come on.
What the hell can I do?
AND!!
when the E-Brake is on, my foot on the brake, and the turn signal on, there is a clicking coming from the e-brake area. ALL this never happened before the lights were put in.
I have a 98 Civ coupe. Bought 99-00 style knock off ones.
Thanks for any help if it comes
Modified by Si Arn at 2:31 AM 5/13/2003
AND!!
Re: (Si Arn)
it happened to me... you gotta switch the bulb... ..you r using either wrong bulb.. or u connected those lilight bulb opposite way... if itz not .. i donno.. ..
Re: (Si Arn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si Arn »</TD></TR><TR><TD CLASS="quote">what do you mean switch the bulb? Take out my stock ones... put in the slots of where the new ones are?</TD></TR></TABLE>
You probably have a single element bulb where a dual element bulb should be.
Re: (Si Arn)
well, are you using stock bulbs?.. well, i had aftermarket tail lights and bulb, but when i put my stock taillights back on.. i realize that my signal is fucked up, itz like showing 2 both signals front when i took brake.. when i drive signal works, but when i take a break it won't work.. so i took out the bulbs then put the stock ones.. then it worked fine.. so i think you gotta play with bulbs...i donno... thatz how i did..
Re: (Si Arn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si Arn »</TD></TR><TR><TD CLASS="quote">ok ok... you have helped me. Thank you</TD></TR></TABLE>
honda-tech.com serving since 19**
Re: (euclid)
did you swap harnesses too? when i changed to 2k rears I didnt change the harness back to my 97 one and it did that...swapped it back to original and problem solved
Re: (pdiggitydogg)
yep... I just went and put the original harness back in and the problem is solved. I just took out the entire harness from the outside lamps. And put the stock harness in its place and the problem is gone
Re: (euclid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by euclid »</TD></TR><TR><TD CLASS="quote">you have to return them to your local pep-boys and write APC a non-threatening letter displaying your contempt. </TD></TR></TABLE>
lol
lol
buttsneeze
04-20-2013 08:34 PM
BIGef
01-17-2013 03:08 PM
tantrumcrx
05-12-2010 08:19 PM
