my ek leaks radiator fluid HELP
well when i turn my car on radiator fluid leaks on top of he back of my headerwhere the o2 sensor is.. and i checked all the pipes and thermostat.. i kinda believe its the water pipe... can someone help??? pleasss
I'm not Rick!
Re: my ek leaks radiator fluid HELP
more checking and inspecting. clean it up and hav sum1 start it and find exactly where it leaks from.
water pipe? you mean the radiator hose? if so jsut get a new radiator hose
well its leaking near the firewall.. the metal pipe that connects to the water pump... its leaking around that area.. an it drains all my radiator fluid!
I'm not Rick!
yeah it sounds like its the heater core. where 2 hoses go into your firewal to feed the heater. drain your coolant. replace those 2 hoses and while you at it check the 2" metal pipes the hoses attach to and see if they are punctured. good luck. you can do this from up top or down below under it
I'm not Rick!
do what i did then. cap the to hoses to the heater. 1 on the head and the other on the thermo tube. and rip out all the heater stuff....but then again. i have nothing in my car but a motor
Yeah only when it's on
I found out what it was though.
The water pipe is loose where it connects to the thermostat.
Me and my brother just took out the whole thermostat and put it back in carefully and
tight.
Turned my car on and no leaks.
tight.
