My EG is smoking....
Someone help me.... I got a 94 DX hatch... and when it goes above a certain RPM it starts smoking... BAD... and it smells like oil... Could have i blown a head gasket?
Re: My EG is smoking.... (b18b EG)
I had that problem before with my gsr and i popped the hood and saw oil everywhere. Finally i took off the valve cover and saw that the gasket was in 2. So check that before a head gasket and also see if you have any leaks. Hope that helps and good luck.
Re: My EG is smoking.... (Luserkid)
it could be a lot of things.....i had a problem with my EG smoking, and it was the crank seal and the rear seal.....al the time i thought it was the oil pan gasket and had replaced it like 3 times thinking it was a bad job each time ...just try and find somewhere that can check it for you...i took mine to a napa car care center and they checked it for free...good luck!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18b EG »</TD></TR><TR><TD CLASS="quote">Someone help me.... I got a 94 DX hatch... and when it goes above a certain RPM it starts smoking... BAD... and it smells like oil... Could have i blown a head gasket?</TD></TR></TABLE>
The rings are most likely going. Do a compression check and leakdown test to pinpoint the problem but a headgasket would show other problems.
Re: My EG is smoking.... (TurBoXBirD16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurBoXBirD16 »</TD></TR><TR><TD CLASS="quote">what color of the smoke??
white or blueish black? this can narrow it down.
Re: My EG is smoking.... (SleepyDX)
tell it to try the patch, that helped my mom quit smoking.
correct me if im wrong but:
blue smoke= coolant
white smoke= oil
black smoke= too much fuel
blue smoke= coolant
white smoke= oil
Re: My EG is smoking.... (LS-hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LS-hatch »</TD></TR><TR><TD CLASS="quote">tell it to try the patch, that helped my mom quit smoking.
blue smoke= coolant
white smoke= oil
blue smoke - oil
white smoke - coolant
black smoke - running rich
yea, could be alot of things, but it is burning oil.
blue smoke= coolant
white smoke= oil
blue smoke - oil
Re: My EG is smoking.... (tominos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tominos »</TD></TR><TR><TD CLASS="quote">
blue smoke - oil
yea, could be alot of things, but it is burning oil.</TD></TR></TABLE>
dam beat me to it.
blue smoke - oil
dam beat me to it.
Re: My EG is smoking.... (sleeperciv)
Unless it's valve springs or very large amounts of blowby oil will appear white when you notice it in the rearview. Maybe a slight blueish tint but it will still look white.
blue smoke - oil
thanks for the correction, its just one of those things that any other day I would get it right but today I couldnt remember.
blue smoke - oil
my pvc(pcv?) was clogged, causing the oil flow to go elsewhere(mechanic said it was burning up in the intake). got it replaced, still burns oil like an old honda(not worth it to do compression testing, for me anyways) but burning went down significantly.
