My Eg got stuck in a flood,IS it necessary to remove the carpet to prevent rust??
Re: My Eg got stuck in a flood,IS it necessary to remove the carpet to prevent rust?? (rocco)
My car got flooded once with about 1" of water. I had to take the carpet out cause everytime it got cold at night the windows would ice up on the inside, and scrapping ice off the inside of your windows isnt fun.
I would to be on the safe side.
Plus it's probably soggy on the underside of the carpet still.
Edmonton hail storm? I feel for you man, I was in the middle of an oil change
best of luck with the carpet.
Re: My Eg got stuck in a flood,IS it necessary to remove the carpet to prevent rust?? (ichiban00)
You need to remove the carpet and clean it , then let it dry out. hang it up some where dry.
Re: My Eg got stuck in a flood,IS it necessary to remove the carpet to prevent rust?? (civicaleg)
yeah remove the carpet so the interior can still be in good condition
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicaleg »</TD></TR><TR><TD CLASS="quote">You need to remove the carpet and clean it , then let it dry out. hang it up some where dry. </TD></TR></TABLE>
do that or if you leave it in there i think it would start to smell.
take it out and clean it unless you like the smell of ******* in your car.
Re: My Eg got stuck in a flood,IS it necessary to remove the carpet to prevent rust?? (zer0_2_6ixty)
****,come to think of it,my ecu was under water,is that as good as fucked?
Maybe, but don't count it out. Just make sure that everything is dry before you try and start up the car. Also remember you have to crank the engine manually to get any water out of it...Im sure you knew this already.
Re: My Eg got stuck in a flood,IS it necessary to remove the carpet to prevent rust?? (TeamCracka)
yea that happened to me in the summertime cause my hatch has a nasty leak. my carpet started to smell like dog ****!! so i ripped it all out and gutted it and took out the sound deadoner and sprayed in gloss black. i like it 1000 times better
UfoTofU
08-17-2006 07:18 AM
