My D15B SOHC VTEC dyno (JDM VTi)
internally motor is stock, its only 1.5l D15B, SOHC VTEC (9.3:1 c/r) (came from EG4 Civic VTi, LSD tranny 4.25fdr)....mods as follows:
GSR TB
old school 4-2-1 lightspeed 1pc header
exhaust (RSR 60mm)
drop in filter (monster sport)
dyno 1: P28 Stock ecu with raised rev limit and vtec at 5100 rpm
dyno 3: B16A Skunk2 program (4800 vtec)
dyno 4: SOHC VTEC RPT proggy (4200 vtec)
enjoy and comment.....also as you can see, my chips do make power
my website
http://www.geocities.com/gtssport/
[Modified by eg6ajk, 5:41 PM 11/23/2001]
[Modified by eg6ajk, 6:36 PM 11/23/2001]
GSR TB
exhaust (RSR 60mm)
my website
Re: My D15B SOHC VTEC dyno (ChopSuey)
b16a = been there done that...and think for over $2000 you will spend on B16a (complete swap), stock motor will only put out 140whp and about 100-102lbs of torque... this only cost me $600....and that includes a JDM LSD tranny, headers, new axles, new mounts, ecu and much more....
so to gain about 23whp with b16a with spending $1400 more i'll pass....for about $400 i'll get a Zex cam and springs, shave the head and will put out similiar power, but i am going to weight at least 100-150lbs less....and less headaches, and if anything breaks...its cheap...
d-series power here i come
here dyno of my b16a:
[Modified by eg6ajk, 5:02 PM 11/23/2001]
Re: My D15B SOHC VTEC dyno (eg6ajk)
Hey, what is your timing settings? are they advanced at all or set at stock with advanced maps? Was the car running rich with the skunk2 program? Im really interested to see your progress. After you get the zex cam, please post your results, I really want to see another dyno sheet on that cam.
Re: My D15B SOHC VTEC dyno (stkd16z6)
1 degree adv. over stock...the ecu/proggy does advance the timing and improve the maps (both fuel and ignition), but decreases gas milage over stock...., and yes the SKUNK2 does run rich, even when i used to have my b16a, it was rich....
Re: My D15B SOHC VTEC dyno (DragIIcivic)
um, i don't think a stock D15B puts down 110 hp ... my d16z6 ex only put down 101 to the wheels bone stock. i find that dyno rather impressive.
Re: My D15B SOHC VTEC dyno (vactor)
in my experience the D16y8 puts down 107-111 stock...I was under the impression that his engine was reletively similar to that.
Re: My D15B SOHC VTEC dyno (On Point)
i disagree. that is nice amount of power. i am sure it is not for drag racing. i am going all motor on my D16Z6. i think that 17 hp over stock (compared to my motor) is Awesome!!!
D Tranny Guru
Retard the cam 2 degrees to move powerband upwards in the rpm a little.
Nice little dyno. Looks alot like my non VTEC 1.5L did.
Should have used a AEM for another 10 hp on topend.
BTW where did you get the swap from?
i always had faith in the sohc motors but my faith has been reassured with your dyno plot thank you!!!!!!!!! so with the SOHC VTEC RPT proggy (4200 vtec) chip is this the chip that you sell if so i am very interested i have a d16z6 that has been bored to a 1.7 liter well rebuilt to a 1.7 i should say hehe and a bullfrog throttlebody and a straight pipe by the way what diameter is the bullfrog tb anyway can someone tell me and can you get a hold of anymore trannys like yours i might be interested in one again props on the numbers they are very good
sohc power
lata
chris
sohc power
lata
chris
Re: My D15B SOHC VTEC dyno (01VaS2K)
thanks...I think the dyno is not all that bad, considering thats its only a 1.5l stock motor, most stock 1.8 b18a/b LSs, make similiar power, but have one more cam, .3l more of displacement, more aggressive tuning (and put out only about 7-10lbs/ft of torque more)....
will try that setting mista bone....need to break into 120whp and over 100lb/ft of torque...
yes all the chips i tested, i do sell...as far as the tranny, i can get it, but i simply do not want to ship...so pick up only...
more dynos:
http://b16a.com/dynocenter/home.html
[Modified by eg6ajk, 5:38 AM 11/24/2001]
more dynos:
depends on how inclined you are with a soldering iron...and some simple knowledge of electronic....the rest is just following my instructions....
Re: My D15B SOHC VTEC dyno (owen_the_soyboy)
lip is a JDM 96 specR (ITR), needed some modifying but it does fit well...
invloves cutting in half and taking about 1-2" of both sides in the middle then simply attachinf with screws, since the OEM mounting poits are different..
similiar to this lip is the 99-00 si/sir coupe...which should just bolt on to the the EG chasiss...but buddy did it on his ex sedan...
Risky Business
Re: My D15B SOHC VTEC dyno (EG1)
amazing gains with simple ecu tuning...I have a d15/z6 mini me...i'm trying to decide wether to advance or retard my timing? how will I know, or do I need to dyno tune it?
EDIT: didn't realize this thread was 2 years old...sorry
Vice President/CEO
Re: My D15B SOHC VTEC dyno (BauleyCivic)
http://www.hyperducktuning.com/ for all your vtech needs.
NoN-OBD (1988-91 cars) - NonVtech
OBDI (1992-95 cars) - Vtech
OBDI (1992-95 cars) - NonVtech
errr
errr
