my car is overheating
Old 05-25-2004, 05:30 PM
VtecbOi's Avatar
Default my car is overheating
i have a d16z6 turbo charge boosting at 7 1/2 and i don't know my car was fine for like 3 months then somehow it just start overheating. the water meter goes up slowly then for like 1 to 2 minutes it goes back down like crazy. does it all the time. first i firgure it might be the radiator. but um.. didn't happy b4 and i'm not even burning tire. so it think it's the water pump and if it is where can i get one and what brand.
Old 05-25-2004, 05:37 PM
DaWorm's Avatar
yeah make sure those radi hoses are all hooked up and goin right, and make sure the radiator itself is all good in the neighborhood. haha. good luck.
Old 05-25-2004, 05:40 PM
Moderator
chad's Avatar
Default Re: my car is overheating (VtecbOi)
SEARCH FUNCTION IS YOUR FRIEND.....why because i did a write up on why stuff heats up!
Solbros Owns Me
Evs-One's Avatar
Default Re: (DaWorm)
probably a leaking headgasket from all the boost
Old 05-25-2004, 05:42 PM
VtecbOi's Avatar
it seem to me like none of yall know anything. i believe the water pump fail. cause my water meter goes up and down like crazy...
Old 05-25-2004, 05:50 PM
hatchy92's Avatar
but before you do go and change the water pump, you may just want to check the simple things like the thermostat, hoses, MAINLY the radiator. Unless it is wasy for you to do the water pump then by all means.
Old 05-25-2004, 05:58 PM
VtecbOi's Avatar
i already did all of that, and yes i change the coolan...
Old 05-25-2004, 06:04 PM
JDM EJ1 95's Avatar
just checking.. you bled the system good right?
Old 05-25-2004, 06:10 PM
VtecbOi's Avatar
Default Re: (JDM EJ1 95)
let the engine warn up. turn the heater to max on hot. and bled it till there was no air.....
Old 05-25-2004, 06:52 PM
Solbros Owns Me
Evs-One's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecbOi &raquo;</TD></TR><TR><TD CLASS="quote">it seem to me like none of yall know anything. i believe the water pump fail. cause my water meter goes up and down like crazy...</TD></TR></TABLE>
haha, you are an idiot.
no help for you
Old 05-25-2004, 07:08 PM
AnToNy's Avatar
i had the same thing happen to me, except w/o turbo. mine was a sensor near the head, that was not telling the fan to come on! could be on urs??
Old 05-25-2004, 07:12 PM
mikehawkBUiLT's Avatar
Default Re: (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika &raquo;</TD></TR><TR><TD CLASS="quote">probably a leaking headgasket from all the boost</TD></TR></TABLE>
i bet
Old 05-25-2004, 07:18 PM
Sushi Buffet Champion
GapxGuy's Avatar
When does it go up and when does it go down?
Old 05-25-2004, 07:52 PM
93Civic_hb's Avatar
Default Re: my car is overheating (jaedaEG)
Thermo switch
LSej1
25
10-24-2011 07:57 PM
DumaDA
06-25-2011 12:50 PM
92civicx
09-18-2007 07:08 AM
greasemonkee
11-24-2006 01:22 PM
1 2 NV
05-12-2002 09:16 AM
Quick Reply: my car is overheating
