My car is broken! Pulsing REV during IDLE and radio memory loss :-(
I was messing with my stock head unit yesterday. I was hooking up an amp, using a hi/lo freq. converter and a few other things.
I couldn't get amp to work so I pretty much put everything back.
Now, every time I turn on my car, the radio forgets the programmed stations (or even what station it was on last)
I think the constant power supply (not the acc ignition) isn't getting power anymore. Is there a fuse or something for that?
I checked fuses and they were all good.
ANOTHER thing. Now when my engine is idling , it constantly revs up a little, like someone is pumping the gas.
WHat is going on!?
WHat is going on!?
New User
Re: My car is broken! Pulsing REV during IDLE and radio memory loss :-( (HybridHatchback)
You either have a bad fuse like you said, check ecu and radio fuse under hood, lift off plastic latch. Might be under and to left of steering wheel too - two fuse locations. Or neg. batttery cable is loose.
As for the idle, your just low on coolent...
[Modified by w00t!, 7:43 AM 1/28/2003]
azz_kicker
Audio / Security / Video
08-19-2006 10:34 PM
