My B16 is pissing me off!!!! -_-
1 Post
help me out guys.... anyone with similar experience/incident/problem??
My B16 doesn't rev as fast as it used(can't feel it pull like it used to...) to and I could BARELY hear when VTEC kicks in... but ONCE IN A WHILE my engine runs FINE/STRONG like it's supposed to(WTF ) UNTIL it warms up... and THAT is what drives me nuts!!! It's like turning a light switch ON and OFF every other day(revs upto 8200rpm fine tho)... I'm GUESSIN my compression is OK....
maybe it's my wiring? I doubt it(checked).. 'cause I don't get no engine codes...
Things I've replaced since that happened(for almost a 4 months now.. )...:
-spark plugs/wires
-FPR
-cap/rotor
-air filter
-upgraded my Civic rad. with an Integra rad.(I thought my B16 was hottER than it should be when running... which I don't think it was NOW )
-.....and I think that's it...(obviously I'm gonna go for compression/leakdown test)
It still didn't solve the problem... What I'm thinking about replacing next is my CAT.(straight pipe)
What else should I try? What do you guys think/recommend other than compression/leakdown test(kinda scares me... )?
Thanks
Hoya
PS. my engine DOES NOT burn oil...
EDIT** I did the valve adjustment too
[Modified by hoya_10fintec, 5:33 AM 3/23/2003]
-spark plugs/wires
-FPR
-cap/rotor
-air filter
Thanks
Hoya
Re: My B16 is pissing me off!!!! -_- (hoya_10fintec)
I kinda had a simaler problem like yours, Check your timing belt tensener. someone told me that it can do that. but what solve my problem was that i put in a ITR fuel pump, the whole AEM fuel products and MSD igintion with blaster coil. that **** solve my problem
1 Post
Re: My B16 is pissing me off!!!! -_- (SymphonyX)
the timing belt's fine... but don't know about ignition timing tho...
no one has the timing guns with the number-indicator to show you where your at... not even a Honda dealership... oh, where I live has the population of 2500... What do I expect?
your belt might be fine, but what about the tensenier??? if its going bad, it can **** up the drivablity. is it a stock B16?? why don't you advance the timing on it to see what happens, you just may have to use 91 octane. that should help
1 Post
[Modified by hoya_10fintec, 6:25 AM 3/23/2003]
Re: My B16 is pissing me off!!!! -_- (boostedcivicsir)
I'd check your oil level, and if ur running a Fram filter or any really "good" filter just go ahead and replace it with an OEM one from honda. those are my thoughts.
1 Post
Re: My B16 is pissing me off!!!! -_- (BigZ88)
the oil level's fine.... but oil filter? it shouldn't make THAT much difference tho, should it?
I mean, the engine runs fine ONCE IN A WHILE... and it seems running better at night...
I'll give it a try tho...
Thanks
[Modified by hoya_10fintec, 3:46 PM 3/23/2003]
Thanks
I'd start by replacing the fuel filter. Those can cause problems and you'd never even know it. And your FPR.. it has to be set right, hopefully it already is. And I'd personally look for a B series fuel pump. I've heard you can definetely notice a difference in upper RPM power with a more efficient fuel pump (which I need to get myself).
Start eliminating more of the small things. But yah, get that compression check too.
Re: My B16 is pissing me off!!!! -_- (Nameless)
is the car gettin up to temp?..maybe it's your thermistat, i know when mine when bad the car felt really sluggish, especialy scince vtec wasent engaging.
Re: My B16 is pissing me off!!!! -_- (blazinb16)
check your O2 sensor. Does it buck sometimes or seem like it lags? It might be the O2 sensor or the wires that go into the plug.
s
s
1 Post
I'll keep tryin... and yeah, I'll check my O2 sensor...
Thanks a lot guys!!
does it seem like your car don't want to go sometimes? My bro's hatch had a clogged cat, and I couldn't figure it out. So I went with all the tune-up stuff and then finally found out that the cat was bad. Order one from summit, it's only $100
actually the oil filter can make a difference. A very restrictive oil filter on a vtec engine can cause the same problems as a low oil level. It doesnt always happen, and symptoms are similar to his description with it working sometimes and not others. I had a similar feeling about my engine till i went to a honda filter. I got the advice from the guys up at IAS but had heard it from a few other people on the boards here as well.
New User
VTEC doesn't kick in until engine is warm, usally up to 10 minutes. FYI
Anyway,
Clean intake manifold for carbon build-up.
Replace fuel filter, no cheap crap.
What plugs did you install? Did you TQ them?
Have you tried fuel system cleaner/treatment, Chevron stuff w/ techron fuel treatment suff is awesome!
Replace PCV valve if you havent in the last 9 months. Better yet, make an oil catch can, nerdsports style!!!
Spark plug wires changed?
Anyway,
1 Post
Re: My B16 is pissing me off!!!! -_- (w00t!)
VTEC DOES kick in(after warmed up obviously..) but I could barely hear it...
Sounds more like my exhaust(cat.) is clogged or something... I'm about to replace my cat. with a straight pipe now at a shop... I'm gonna go from there... if that doesn't work,
then fuel filter --> fuel pump --> O2 sensor --> blah --> blah...
PS.sorry if this is a noob Q but what does PCV valve do?
Thanks!
Thanks!
Mr. Badwrench
POSITIVE CRANKCASE VENTILATION
it is a one way valve that allows crankcase gasses to be removed via intake manifold vacuum.
1 Post
YES!! I finally fixed my problem!!!
I finally got around to replace my fuel pump with GSR one... WOW! what a difference!! engine's running perfect now except for the speeding ticket I got on the same day for testing...
I just thought I'd let you guys know..
drunken jdm monkey
10-04-2003 10:58 PM
