MY AC blows warm
MY AC blows warm
When i was buying a car i was specifically looking for one that had air conditioning due to the fact of just moving from washington state to hot *** south carolina so i pick up a 95 civic ex with air conditioning but like a dumb *** i forgot to make sure it worked i pushed the button heard the ac come on and then just turned it off the problem is it doesnt get cold at all it basically feels like i just slide the temp gauge on the dash all the way to cold and had the ac off and turned it on you know kinda like a pretty warm air that should be cold i have tried to recharge it, its fully charged. what else could it be?
Re: MY AC blows warm
yes the fan comes on idk if the compressor clutch engages where would you look for that and yes the light turns on when the button is pressed im guessing i would look if im looking at the motor to the front right of the header like right behind the driver side headlight and what would it look like when its engaged
thx
thx
With the engine running and the A/C off, the faceplate (clutch) on the compressor should NOT spin with the pulley.
With the engine running and the A/C on, the faceplate on the compressor should spin with the compressor pulley whenever the condenser fan runs.
Before recharging with refrigerant, was the system empty? Or did you recover, evacuate, and then recharge the system?
im pretty sure that thing just spins constantly i will have to look again but when i tried recharging it i just went and bought a thing to recharge it and put it on the appropriate nozzle and it said fully charged thats all i did should i do something different
How much refrigerant did you add? It's very unwise to add refrigerant to a system before measuring refrigerant pressure on both the high and low sides using a manifold gauge set with the A/C running. Without this information, you don't know whether the system is full or has air in it or another problem. Diagnose first, then repair.
Click here.
Hey thanks man thats going to help alot i will work on it a lil tomorrow and then figure it out where im at from there and get back at ya thanks for the help
clutch plate / face plate does engage when turned on and it turns off when i turn it off so that part is functioning properly still trouble shooting if ya'll have any other ideas as well i would love to hear them
thx
thx
Hook up a manifold gauge set and measure the high and low side pressures with the A/C on and the engine at 1500 rpm.
ok so i read the forum thing that link you sent me and did wat it said it worked to an extent its alot colder but not seriously cold it said something checking the radiator to see if it is filled up you know by squeezing the lines top and bottom and checking the fluid and i did that does that help? idk
im sure it does but idk how i dont get that i guess i didnt think it had anything to do with the ac
If your engine is overheating, the A/C won't work as efficiently. Did you measure the refrigerant pressures?
no my engine isnt over heating but i was low on fluid in the resivoir so i filled it up still looking for some time to measure the refrigerant pressures you need hi and low right?
