My 94 civic coupe EX is sluggish
Hey guys on my previous thread i was having fuel pump issues, now that all that is solved, ironically when i started my car it ran like ****. i knew spark was good so i pulled the fuel rail off and turned the motor over a few times, and an injector was stuck open. (last night) Then this morning at 7am at 30 degrees F out i wired in a b20 injector to replace the one that was stuck. obd2 i beleive. came off of a 97 crv. so this morning we took off (had to take my girl to work) and i left an EPIC blue smoke cloud that you couldnt even see through.after that it started to clear up, now its not smoking at all (leftover gas or???)
MY motor is a D15B vtec.
Now that i put the b20 injector in its idling funny, but after i get up and going past 1.5k it runs just fine. (rich?)
Like i said before im still having my very strange power cutout, i will get power cutout sometimes if i give it more then 1/2 throttle and stay cutting out unless i let off of the gas, and ease back into it, it clears out at 3k rpm and doesnt do it after 3k rpm.
Car has aem fuel rail, pressure regulator, new fuel filter, new cap, rotor, and plugs/wires, and good compression so wtf?
anywho thanks in advance fellow honda lovers
Going to post up a new thread with pics and all the goodies of the car you are helping me with.
Re: injector compatability / slugging issues.
bump +
car still sluggin around, after 3k it clears out, if it does it, when it doesnt do it feels pretty good. feels quicker then before my other fuel pump went out (maybee because i havent driven in a week lol)
Not sure whats wrong with your car but blue smoke would not be too much fuel. You are burning oil.
I would try putting a stock rail and regulator back on to see if that makes any difference.
sorry let me write down what i have done and changes that have occured.
-changed fuel rail / injectors / pressure regulator
-changed fuel filter
-blew threw fuel line to assure there wasnt a clog.
-did plugs/wires/cap/rotor
-have fuel pressure but unsure of actual PSI
-replaced fuel pump (went out)
-cleaned fuel pump sock
-cleaned intake mani/T.B. SPOTLESS inside
-map working properly
-TPS working properly
-O2 working properly
-Switched ECU's.. ECU working properly
-fuel cleaner no effect
Probably more things.. all above had no effect.
1994 civic coupe EX no CEL... never messed with timing, checked timing and its spot on to factory specs, engine is a jdm D15B vtec
okay so now i got all good stock injectors for my motor, just finished wiring them in. SO now it runs WAAAAAAAYYYY better... But im still having the sluggish issue, i can kindof hear a miss when i rev it at a standstill...
like i said, sometimes when i half throttle it it will sound weird like a subaru, no vibrations,knocking, or any other noises, and it feels like my power got cut in half or more. i have a camera but for some reason the mic doesnt work. otherwise id film it.
A friend who is a honda mechanic who i also bought the car from, told me its related to the throttle body. It was doing the infamous wandering idle... 900-2000 rpms up and down up and down.. i blocked off the bottom hole before the butterfly in the Throttle body, and that stopped the wandering idle issue.. looked at the whole setup and its some kind of air bypass it looks like? no electrical or sensor hooked up to it so that cant be the issue can it?
I really need help.. my girl drives the car mainly because i dont have a licence.. thank you in advance
Re: My 94 civic coupe EX is sluggish
IACV is super clean.. And forgive me but what is FITV?? what does it stand for i mean. And yes my CEL works, it lights up when my fuel pump primes
oh the air valve on the bottom of the throttlebody? i blocked it off completely... would that cause my issue? blocking it off i mean
^Well, let me answer your question with another question. Is it really ever smart to block something that came OEM and is intended to allow the engine to run right?
start the car let it idle take some carb cleaner and squirt around areas of the intake mani hit sensors anything that air might escape if you get a stutter that is most likely where your having issues (if its a vac/air leak issue)
NortesidinII
10-29-2010 10:42 AM
Hurricane
21
09-23-2004 08:07 AM
