My 2000 si
Old 12-23-2008, 07:15 AM
2000sidohc's Avatar
Icon3 My 2000 si
I do have aluminum Heads on my EM1 right.
Also to do cams would i have to pull the motor.?
Thanks
Old 12-23-2008, 07:28 AM
cvcdx's Avatar
Default Re: My 2000 si
no you don't have to pull the motor out... i wouldn't recommend changing your cams unless you have the basics air intake/header/exhaust... without upgrading these parts you will not get the most out of the changing the cams
Old 12-23-2008, 08:16 AM
Hanmin's Avatar
cams wont gain power unless you get a tune, if your lucky. to get the most out of more agressive cams, you want higher compression pistons.... So I've read. and all honda piece of **** fairy cars have aluminum blocks.=]. Hmm, if anyone knows, are the sleeves aluminum too? i don't think it is but I would like to hear it from someone who actually knows.
Old 12-23-2008, 08:29 AM
Resident Gearhead
BryanM.'s Avatar
B and D series engines have aluminum cylinders with steel liners. The F20C/F22C and some (if not all) H22s have FRM cylinder liners.
Old 12-23-2008, 11:35 AM
cvcdx's Avatar
my point in the post was that cams in a stock vehicle would be pointless if you haven't already opened up the air passage to the motor and decreased back pressure in the exhaust... i do agree that a tune is needed to be able to adjust the timing and fuel depending on the cam profiles
g23cg5
11-15-2013 04:58 AM
FA5civicSI
Honda Civic (2006 - 2015)
10-18-2008 06:19 PM
0c00l
01-03-2008 11:43 AM
precisionelite
01-11-2006 11:06 AM
Junglist
01-03-2003 08:59 PM
Quick Reply: My 2000 si
