my 2000 honda civic turn signal/hazard went out
Old 12-16-2012, 10:35 PM
jessiehonda75's Avatar
Default my 2000 honda civic turn signal/hazard went out
i need help..i found the relay..i move it and nothing...maybe is diconnect?
Old 12-17-2012, 05:45 AM
Former User's Avatar
Default Re: my 2000 honda civic turn signal/hazard went out
Are the fuses blown?
Is the switch unplugged?
Old 12-17-2012, 06:56 AM
B_Swapped93's Avatar
loose wires/burnt-out bulb bad socket give those a check
Old 12-17-2012, 11:20 AM
i check the ac switches are connect right..headlight and park lights works..got the relay and nothing still nothing working..
Old 12-17-2012, 12:52 PM
HondaCivicSE's Avatar
pull out the fuse and check to see if its blown
Old 12-17-2012, 08:20 PM
hondacivicse which fuse?
Old 12-18-2012, 05:14 AM
10A hood fuse 53 - hazards
7.5A dash fuse 12 - blinkers
Voltage test both. See fuses link in my signature.
Also check whether the hazard switch connector is unplugged.
Old 12-18-2012, 06:23 AM
civicguy395's Avatar
it is possible for a fuse that looks good to be bad so make sure use a fuse tester i would then make sure i had a voltage meter and check to make sure voltage is actually getting to the fuse with the hazard or blinkers on
Old 12-18-2012, 06:30 PM
i got fix thanks guys..was diconnected..
was a hell job to connect it back..thanks you all for the info and help..
Old 12-18-2012, 07:00 PM
now more bad news..car turn on great..but it was before overheated abite..smoke a littie bit..what can i buy to stop the smoke?smoke only when i start the car only..
W95civicEXcoupe
03-02-2015 10:25 AM
Masho
Honda Civic (2001 - 2005)
07-17-2010 02:24 PM
FRKWOO
13
05-28-2009 11:48 AM
queda
05-23-2008 08:42 AM
ModlesSI
02-22-2003 03:16 PM
Quick Reply: my 2000 honda civic turn signal/hazard went out
