my 2000 civic ex with gsr swap wont spark
i have a 2000 civic ex with b18c1 okay so car started up one day then i left the car outside over night in the cold and it didnt want to start so i got a new distributer and rotor ,cap,plugs and car still doesnt spark also checked all fuses car has good comprestion and firing order is right also tryed 5 differnt ecu and still nothing so i need help ?????????????????????? if anyone has a idea what it could be plz help me out
Re: my 2000 civic ex with gsr swap wont spark
Is 15A dash fuse 9 blown?
Does the Blk/Yel wire in the distributor have battery voltage with the key in ON(II)?
Did the timing belt snap?
Get the coil and the ignition control module tested and also check to see if your getting fuel at the fuel rail. If those check out o.k then check to see if your timing belt didnt break off.
yeah chECK FUSE #9 its good timing belt is good and i am getting fuel to the fuel rail How do i check the coil and the ignition control module? thanks
check if your ecu is not burnt?. ask a friend to let you borrow one and try it....cuz last time this happened to me. i replaced everything for no reason den out of nowhere my boy comes like nothing switches the ecu's and it turned on ifelt like a idioit for a whole month i was car'less
mitch truth
12
05-17-2019 05:41 AM
dwillms
09-16-2014 06:50 PM
NetRyderz
14
07-04-2005 03:42 PM
