my 00 si header is red hot, check engine lights is coming one?? it the cat messed up?
my 00 si stock header is red hot, check engine lights is coming one?? it the cat messed up?
Re: my 00 si header is red hot, check engine lights is coming one?? it the cat messed up? (gulftires
Have you not noticed a susbstantial decrease in power?
A clogged cat will cause things to get red hot.
Maybe your timing (ignition/cam) is so far off that your tossing a still burning a/f charge into the exhaust manifold.
Have you done some recent modifications/maintenance work lately?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gulftiresinc »</TD></TR><TR><TD CLASS="quote">my 00 si stock header is red hot, check engine lights is coming one?? it the cat messed up?</TD></TR></TABLE>
you mean coming "ON" or throwing code "ONE"
you need to check what code you are throwing - see here
https://honda-tech.com/zerothread?id=745413
here is a list of the codes
http://sirrommotorsports.com/s...=1716
i have a **** load of losed power!! punching out not even going fast!!
why would a cat on an 00' civic need to be replaced already.
just curious?
just curious?
