my $300 project
my $300 project
i just bought a 300 eg with 122,000 miles it ran for one day and while goin in reverse i accidently dropped the clutch and now it wont turn back on it will turn over but not start any ideas about whats causin this also when it ran piston 3 would misfire please help
Re: my $300 project (mpower325)
first things to do in any situation is check for air fuel and spark, make sure it has those then move from there. the first thing i have always done when buying used cars is give it a tune up and oil change. mis fire could just be bad spark plug, wires, or distributor cap
i may be stupid but im not following what u did. did it stall out and not start again? were you able to get to where you were headed and then never started again? was in raining when there was a misfire?
your foot slipping off the clutch pedal won't cause the car to not start again....your problem has got to be that misfire
It sounds like its uber tired in the engine department. im guessing with the conversion into kms from miles its over 300000k on that engine and trans. If youre planning on using it as a project i would start by pulling it out instead of pulling your hair out trying to troubleshoot various issues with it. Thats my opinion.
Re: my $300 project (BADHDRIVER)
iight so i was drivin and i put it in reverse my foot slipped of the cluthand the car jumped and died when i tried to start it the engine would not start the misfire had been occuring when the car still ran it would putt every couple of seconds would my wires or distributor be bad because the plugs are fairly new i kno this car needs work the ppl who owned it b4 me were ricers all the way my whole engine is spray painted silver wires and all im plannin to have a friend put in a b18 in it but i want it running untill i can afford the swap
another thing to check is whether or not the battery is putting out enough charge and whether or not the alternator is working. i have a vw corrado that had a bad battery would turn over but not start . i checked for air fuel and spark had all three but because the computer wasnt recieving enough power it was like a alzheimer patient that didnt know what was going on.
there you go! if you're cheap pull dis. cap, clean up see what happens. personally i would change spark plugs wires dis. cap/ rotor. its not expensive and from the way you describe the previous owners it should be the first thing done. if that dasent work come on back and we'll help
Re: my $300 project (adrenalinejunkie)
Im just goin by the fact he said PROJECT poopy head. It makes sense if youre havin problems with a really high milage d just to swap something else in. You may have some problems but all the better to work them out and have a faster car.
do cap/plug/wire/rotor, or change the dist in case the coil went, check fuel pressure by cracking the fitting on the rail or filter case, sounds like the timing skipped
Re: (uneek360)
put the ingnitino key on the second notch.. roll that bitch, put it in second, pop out the clutch if it doesn't start .. theres always a b-series for sale
