MUST READ: LHD Folding Powered Mirrors from USA
#26
Re: MUST READ: LHD Folding Powered Mirrors from USA
Does anyone know the part number for the heated mirror switch for an EG? (92-95)? Only seen one in existance and wondered if there was a part number for obtaining another.
#28
Well I have talked with two different places and both pull up the part numbers and let you buy the item, but you will end up getting a call with them saying they can't get them. So I am not sure where the pictures of the mirrors on this first post came from?
#29
After consulting with Hondapartsnow, the only available stocks scattered in warehouses across the US as of now are:
76250-S03-D15, Unpainted Left, 4
76200-S03-D15, Unpainted Right, 2
76250-S03-D24ZJ, R97 Roma Red, 2
76250-S03-D25ZF, NH583M New Vogue Silver Metallic, 1
76250-S03-D25ZL, NH578 Taffeta White, 1
76200-S03-D24ZD, NH503P Granada Black Pearl, 2
76200-S03-D25ZE, NH538 Frost White, 2
76200-S03-D24ZJ, R97 Roma Red, 2
76200-S03-D25ZF, NH583M New Vogue Silver Metallic, 1
76250-S03-P24ZM, R95P Island Coral Pearl, 5
76250-S03-P24ZP, B73M Cyclone Blue Metallic, 5
76250-S03-P25ZK, R81 Milano Red, 1
76250-S03-P25ZR, R96P Inza Red Pearl, 2
76250-S03-P25ZS, NH578 Taffeta White, 19
76200-S03-P25ZK, R81 Milano Red, 3
76200-S03-P25ZR, R96P Inza Red Pearl, 5
76200-S03-P25ZS, NH578 Taffeta White, 22
76250-S03-U35ZC, G82P Cypress Green Pearl, 1 (Only RHD left green power folding mirror!)
After all these are gone, they are gone. Unfortunately, only a few of you will have LHD manual fold power tilt. A good number of you can have them in Taffeta White. I lucked out on mine but had to share with the community.
#34
#36
can you take these mirrors and swap the guts from a set of jdm power folding mirrors and make a set that can power fold and tilt?
Hopefully that makes sense, I just installed a set of jdm ones and already the drivers side is bugging me.
#37
Oh look, I can change this
^ Yes, but that is a lot of expense to go through to get new OEM ones and then tear them apart. Before you drop that coin, consider getting aftermarket LHD EDM-style ones for the shells. Then swap over the JDM OEM internals. Aftermarket mirrors usually suck but the shells are well-constructed. Cost a fraction of new OEM, too.
#41
JDM, EDM = same difference, just make sure they mount up properly for LHD. JDM is a more popular key word so I'm guessing most outfits use that term. Actually, I just remembered that some Prelude and Integras have the same mirror shells as EDM & JDM, if you're still after OEM. So, your only problem left is the correct LHD mirror mounts on the door (different angle on RHD vs. LHD, but you probably already know that).
#44
Try posting in the forums to find out ppl's opinions on the various mfrs for the mirrors before paying through the nose for int'l shipping to Canada.
#46
Just doing a regular Google search will not do you any good. You have to outsource your searches. Try Google Germany, Ebay Germany, etc.
#47
You only need a LHD LEFT side mirror assembly. You can find unpainted replacement mirrors on German sites if you search carefully and use Google Translate along with it.
I already placed a order for one through Majestic, i'll hang on to it if I can find out from Europe
#48
hey i need to bump this old thread because i want a set of lhd manual folding mirrors.. luckly i need them in taffeta white.. im not sure which part number i need since i see 3 different numbers for taffeta white... the numbers are
if anyone has information on if these are power or non power or even if they are lhd manual folding mirrors for a 2/3 door ek in white please let me know
