multiple strange problems after tuck need advice
hello.
ok so here is the story.
92 civic canadian vx, did a wire tuck with a stock harness converted. also relocated the fuse box and tucked all the lights and other harnesses.
so. its a GSR, on a chipped p28. its doing a code 7 TPS, code 8 TDC sensor, code 13 barometric sensor, randomly doing a code 19 AT lock up (its a manual and always has been)
Now the super strange part. it starts and idles BUT as soon as you it 2400 RPM it dies, the tach just shuts off and dies right as this happens almost like its shutting itself off via ecu or power or something.
ALL THE GROUNDS ARE GOOD so please dont say that. the TPS sensor is also good and and i do not understand the baro sensor or the AT lock up.
anyone have any ideas? main relay seems to be good. i did not cut any of the dizzy wiring or really much of anything that i could just extend. any help would be great
The Grumpiest
Re: multiple strange problems after tuck need advice
My idea is you need to go back and find out what you messed up. No one will have a clue where to tell you to start looking as no one knows how you did your tuck job.
If you loved me, you'd all sell me your magic cards to me today
As others have said, check your wiring. also check your grounds.
BUT GUYS, I HAD THIS PROBLEM BEFORE MY TUCK. THE TUCK SHOULD HAVE FIXED THIS...WHAT DO?
OP, figure out where you fucked up. If it ran fine before the tuck, you messed it up. You kids are hilarious with you lack of diagnosing "skills"
Honda tech, smart *** posts but few smart answers. I was seeing if someone had an idea maybe something similar. But nope just a couple of post ***** idiots that rephrase each others posts in an attempt to bash someone who usually has a better car then they do. Congrats ********!!
And in response to was it worthy of a thread were most of your responses worthy of posting at all? Stop being a buncha ******* hypocrites and try to represent your "community" with some respect. If this isn't a place to ask your fellow enthusiasts for help for fear ridicule then is it worthy of being a forum in the first place?
Basically In short go *** yourselfs. (Limited only to people who posted responses that was solely for the purpose of being asshats) not a representation of everyone on forum.
O.G. triple O.G.
The Grumpiest
You have the "better" car, but YOU tucked it and cannot figure out where YOU screwed up on a custom job and us idiots with the the crappy cars are supposed to help you figure it out when none can POSSIBLY know what you did? Kids these days.
been there done that
PHANTOM MENACE
OP - It all comes back to this:
Emphasis on the second sentence. On top of that, you listed the codes your ECU is spitting out. That should've been the very first hint but since it's not so obvious then you need to look at the wiring to those sensors. If the car was running fine before, there's no reason it shouldn't be running fine now.
wow with that response bud, good luck getting an answer now, maybe you should sit down and shut up, you might learn somethin, but nope too late
streetsold6teeny8
03-24-2012 06:46 PM
underage
07-13-2005 02:33 PM
MEANB18
03-10-2003 06:49 PM
