mt shifter
mt shifter
Im doing a mt swap in a 93 coupe. The mount for the shifter that bolts to the car,do i have to bolt that to the plate that i have to make to cover the hole? thanks
Re: mt shifter
Not that easy.
Yeah, you should probably use the two shifter mounting spots for the sheet metal hole cover. There will be a couple of more holes on the other side to hold it down securely. You could also Bondo over the wind tunnel hole thing (I don't know if this will last forever), and a lot of people use some sort of silicone or sealant to hold the plate down.
96pgtmtx
08-28-2007 11:52 AM
