MSD SCI ignition questions
I have an opportunity to come up on the MSD SCI ignition box and 8.5 mm wires to go with it. I am also still running with an S-AFC untuned. My question is will this be enough for now until i can get my hands on Hondata???
This setup will be temporary because i get a bonus from work which will be used along with some help from my brother to get Hondata. My main question is will it work to get rid of the running rich problem and maybe get some more power out of it???
Electrician
Maybe you're running rich because:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Superdragr45 »</TD></TR><TR><TD CLASS="quote">I am also still running with an S-AFC untuned.</TD></TR></TABLE>
I doubt the ignition box will do anything for your "rich" problem.
Tune it, then come back on here. The OEM ignition system is really good. Unless you're making crazy power, stick to the OEM system.
Re: (Dimi)
ditto man. i kno that. also, i havent driven the car much because of that problem. mainly, once i get the ignition on, i will go get it tuned.............combined with the ignition set-up, can this cure some of the rich problem??
Re: (Superdragr45)
i wouldn't even worry about the ignition. a simple ss coil should be fine unless ur running near 4-5 and up whp. i mean i know people with 350 - 400 with stock or just the ss coil. but whatever floats ur boat. get it if u got the money! .. haha
bboyoxygen
01-07-2005 07:10 PM
