Mounts for EG with GSR Motor
First let me say I did search a bunch and I think I found the answers I'm looking for I just wanted to confirm as my swap is a little different than most.
I have a 1995 GSR Motor in a 1997 Coupe currently. I just bought a VX hatchback in beautiful condition. I need to know what motor mounts I need to change to put this motor in the hatch.
I think I only need the Rear "L" type mount that goes on the block from a 3G integra and the complete mount that goes near the timing belt from a 3G also? Can anyone confirm this?
All my other mounts should work correct?
1 Post
Re: Mounts for EG with GSR Motor (mike1114)
All of the mounts are the 'same' if you have the mounts from the integra (higher durometer)
Otherwise, go do some research on http://www.hasport.com for details on mount kits.
Re: Mounts for EG with GSR Motor (Infamous_Imports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Infamous_Imports »</TD></TR><TR><TD CLASS="quote">These would be the same mounts that you'd need for a b16a3 into an eg also correct?</TD></TR></TABLE>
I used mounts & brackets off a 95 GSR (that is 94+ b-series) on my B16a gen2.
Re: Mounts for EG with GSR Motor (handa)
Thanks but I don't need info on hasport mount kits, I want OEM mounts.
I just need to confirm what I need, the rear "L" bracket and Timing belt area motor mount I had to use on the 97 coupe is from a 99 SI, I don't believe these will work on the hatch.
you need the bracket from the Integra 94+ and also the same on the driver side upper mount from the integra...basically you need all Integra mounts except for the a/c one if you want to retain your a/c...by the way, I have the rear mount and driverside upper mount you need. PM me if you are interested.
