Which motor swap?
Old 07-14-2003, 10:00 PM
JDM CTR EK's Avatar
Default Which motor swap?
Ok. I want to go boost. Which motor should I get, Jspec B16A2 or Jspec B18C Si-G (GSR)?? Someone told me that the B16A2 would be better for boostin' because the engine is stronger or something, I don't know. What do you guys think? I need some feedback! thanks!
Old 07-14-2003, 10:17 PM
HuskerHybrid's Avatar
Default Re: Which motor swap? (JDM CTR EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM CTR EK &raquo;</TD></TR><TR><TD CLASS="quote">Ok. I want to go boost. Which motor should I get, Jspec B16A2 or Jspec B18C Si-G (GSR)?? Someone told me that the B16A2 would be better for boostin' because the engine is stronger or something, I don't know. What do you guys think? I need some feedback! thanks!</TD></TR></TABLE>
I think you and your friend need to do some more research.
Old 07-14-2003, 10:34 PM
Pho Real's Avatar
LS 20 lbs
Old 07-15-2003, 01:39 AM
Mike Ockhurts's Avatar
Default Re: Which motor swap? (Pho Real)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pho Real &raquo;</TD></TR><TR><TD CLASS="quote">LS 20 lbs </TD></TR></TABLE>
what he said. i believe b18b has a lower compression level, making it an ideal motor to boost
good luck
Old 07-15-2003, 05:08 AM
JDM CTR EK's Avatar
Default Re: Which motor swap? (lilredridinghood)
Yea, I've been told to get an LS motor for boost. But I want something with Vtec
Old 07-15-2003, 05:51 AM
tararan's Avatar
vtec don't help much when you already have boost... just turbo your SOHC, you be happier......
Old 07-15-2003, 05:57 AM
jolt-tsp's Avatar
Default Re: Which motor swap? (tararan)
It would be quite a bit cheaper to just turbo the sohc. If you really want to swap first though, I'd say the b18 or LS. The b16 would be great for high rpm NA though.
Old 07-15-2003, 06:33 AM
JDM CTR EK's Avatar
Default Re: Which motor swap? (jolt-tsp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jolt-tsp &raquo;</TD></TR><TR><TD CLASS="quote">It would be quite a bit cheaper to just turbo the sohc. If you really want to swap first though, I'd say the b18 or LS. The b16 would be great for high rpm NA though.</TD></TR></TABLE>
thanks!
Old 07-15-2003, 06:45 AM
Former Moderator
B18C5-EH2's Avatar
No matter what engine you buy, if you want to go with boost over 15psi you will need to build the engine and preferrably sleeve it.
Cost of the engine should be considered along with the costs to build it up for bigger boost.
If your plans are lower boost like 8-10psi then try to find the lowest miled engine as possible.
In any case you'll need some GOOD fuel/engine management like hondata, so save up for that too along with a few hourse of dyno tuning.
You need to do a lot more research before you post such a general topic.
Search the forced Induction forum first.
bigjay1six1
01-03-2008 02:40 PM
teamrpm2
63
12-24-2007 12:16 PM
gsrjohnny
09-08-2006 06:43 AM
integracura
10-15-2005 10:49 AM
da9wonder
06-18-2005 01:16 PM
Quick Reply: Which motor swap?
