motor stays at redlined
pm for noodz
so far its done this twice,it does it when i try to launch of the line,ill hit fuel cut off really fast in first gear so i shift to 2nd really fast and the rpm stays at 8.2k..whenever i go of a roll i dont have this problem.
here the closest thing i could find to it on you tube...just mine does not lag
http://www.youtube.com/watch?v=6WzG0...eature=channel
pm for noodz
pm for noodz
Re: motor stays at redlined
Sounds like a slipping clutch to me. In that video however it sounded like he was just spinning tires.
Put the car in 3rd gear when going like 30mph and step on the gas all the way. See if the RPMS climb rapidly and if the clutch slips.
pm for noodz
in my video?im gonna go head and try that 3rd gear thing next time i go out.
No, not in the video but what you described. Although if it was a slipping clutch it wouldn't just do it from a dig, it would do it when shifting into other gears as well.
Are you sure you're not just spinning in 1st? lol
pm for noodz
i do spin alot in first,and tha time that my car has done this its has been about 20 degrees outside and its been on the same road,maybe its the road thats real slippery...now i feel dumb ..
pm for noodz
Sounds to me, and most others, that your clutch may be going out. Give it the lug test. =P go 30 or 40 mph and just stomp 5th to the ground. If your RPMs climb faster then your speed then your clutch is slipping.
Your clutch is probably gone. When you cruise on the freeway, floor the pedal. If the car just revs up without going faster then that's your problem.
pm for noodz
nah,i dont think its the clutch,i was cruising at at around 50 today in 5th gear than i dropped it to third and floor it and it got up to 90 pretty fast,and it rev how its supposed to,i think that since my tires are cold and the road probably has some dew that my tires are just spinning...
pm for noodz
r4in
12-14-2014 09:11 AM
