motor noise
motor noise
Hey guys i posted on here a while back about my d16z6 making a funky noise, people were saying it was probably a valve tick and nothing to worry about. Now recently the noise got louder and worse. I have a exhaust on my car and now when driving you can here the noise over the exhaust in the car. The noise is there when you start the car for like 45 seconds when you start it up then goes away, and come back when you are driving. Is this a valve tick or rod bearing, how to tell the difference. Any and all help is appreciated.
The Grumpiest
Re: motor noise
And you never posted back to follow up. Before you said it was coming from the transmission.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/ej1-trans-noise-3017595/
Sounds like rod knock. Open the hood and see exactly where it's coming from, block or head. If it's from the block you're done.
Re: motor noise
Yeah for a while i haf a noise in my trans also but a flush and fill fixed the trans issue. I opened my hood and it seems like the noise is comin from the head.
Re: motor noise
just got my car back from the mechanic who took a look at it and no good news. He says that it is piston slap? What is this and will it do any damage to my car that it already has not, any fixes even temp ones. better to try and fix the problem or just motor swap?
Re: motor noise
Lude comment for the slap, but what are your car stats...miles on the motor. Run it till it dies or throw some money at it as in a new car/motor, pretty comparable price to engine work.
Re: motor noise
ok here is a link to a vid i recorded on my phone, its the best i could get tonight. hope it helps explain the noise.
http://youtu.be/2G_VGmDrrYA
Re: motor noise
Aww that sucks!
XP
Hrm...since the bottom is toast, move on past the D-series mini-me!
Heck, for about the same price as piecing together a mini-me like that, you could find a good B-series long block, some axles, and add some wiring and an ECU and throw that all in there, and you'll have a fun to drive little Honda!
There are DIY's for it all over the place too :D
(then sell the toasted motor and trans to make up some of the cost. After that, the overall cost isn't much higher than that mini-me plus you'll have WAY more power potential than any Mini-me will!)
My .02
XP
My .02
Re: motor noise
Aww that sucks!
XP
My .02
XP
My .02
kenskii
07-08-2014 08:33 PM
Luserkid
07-21-2003 05:07 PM
