Motor mounts
Motor mounts
Im doing a gsr swap into my eg. The two front lower mounts are cracked and ive heard that they are not neccesary......is this true? If so im just going to leave them out.
Re: Motor mounts (95hatch)
Assuming you're referring to the tranny mount and A/C bracket mount, it's not 100% required, but I would highly recommend it.
The polyurethane mounts will have a lot of stress on them otherwise.
Re: Motor mounts (liam821)
I would run them.
You can use the ES inserts with your broken stock mounts or you can get the http://www.JIMFAB.com ones pretty cheap.
I run the jim fab
Modified by rolow at 7:42 AM 9/10/2003
I run the jim fab
Former Moderator
Re: Motor mounts (rolow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rolow »</TD></TR><TR><TD CLASS="quote">I would run them.
You can use the ES inserts with for stock broken mounts or you can get the http://www.JIMFAB.com ones pretty cheap.
I run the jim fab </TD></TR></TABLE>
Yes simply pop in the ES inserts into a "broken" front rubber mount piece and you're good to go. Might as well pop in the rear mount insert to complete the ES kit while you've got the engine out, because once it's in that rear insert is a PITA to install.
Re: (johnny5sTypeR)
YOu most definitly should run them. Just use the inserts like every one else said. I run the hasport rear drag mount on mine with the inserts up front. But beware, your car will vibrate more with these inserts.
