This motor curse!
Old 08-30-2001, 07:19 PM
New User
B16Vtec's Avatar
Default This motor curse!
Ever since I swap B16a2 in my EG I had a **** load of problem. First this **** didn't start that been fix. Then this **** happen dam motor overheats as soon I as start the car and let it run for a little. It seem like coolant doesn't pump around, upper radiator hose is hot as hell and the lower hose and radiator stay cold. I bought a new thermostat and **** still the same. Anyone know how to fix this problem?
Old 08-30-2001, 07:26 PM
VTC_CiViC's Avatar
Default Re: This motor curse! (B16Vtec)
If the lower hose isn't hot, then either the coolant passages are blocked or your thermo is bad and not opening the return valve.
Old 08-31-2001, 06:09 AM
DragII's Avatar
Default Re: This motor curse! (VTC_CiViC)
it's possible that the water pump bearings are bad
Old 08-31-2001, 05:41 PM
fixhondas's Avatar
Default Re: This motor curse! (DragIIcivic)
sounds like an airlock to me. Jack the front end up and fill the radiator up and squeeze all the hoses like a pump until no more air comes out- then run the motor.
ge_ej1
11-11-2008 08:57 PM
90crxdxb16
26
08-10-2007 04:06 AM
DRKSol
06-06-2005 04:51 AM
Dumped DB2
02-08-2005 05:53 PM
metal-x
06-25-2003 01:13 PM
Quick Reply: This motor curse!
