motor is burning oil
Old 07-12-2010, 07:59 PM
keithaustria's Avatar
Default motor is burning oil
my motor is burning oil and im not sure where to look first. its a b16a2 and my friend says he can see the white smoke when coming out of the exhaust when i get on it. i can also smell it inside the car when i come to a stop off the freeway...little feedback would help. thanks guys
Old 07-12-2010, 10:07 PM
erichackett's Avatar
Default Re: motor is burning oil
do a compression test. and read from like a helms manual. it will help you figure that out.
Old 07-13-2010, 09:49 AM
Sr420Det's Avatar
More than likely valve seals or steams, Id replace the seals (its pretty simple with the right tool and cheap too). Make sure u check the compression first and make sure the cylinders are sealing properly which would rule out rings.
Old 07-13-2010, 09:59 AM
B16AGUY's Avatar
Just a quick note that it's probaly not the rings if it's truly white smoke that the exhaust is emitting...typically bad rings/burning oil = blue smoke... however, you should still do a compression test as mentioned above to aire on the side of caution and rule out the rings.
just my .02
Old 07-13-2010, 11:05 AM
donovan772's Avatar
I have a b16a2 that burns oil (164,xxx miles on it) It smokes when I get on it, I compression test it and it was like 120,110,90,95 so I have bad rings. So yeah compression test it to be on the safe side. If the numbers are low it's rings. But like these guys said if it's "white" smoke It's probably valve seals.
Old 07-21-2010, 10:04 AM
thanks for all the help guys!!
RedCd5TX
05-10-2008 06:14 AM
j-bird20
01-11-2007 05:59 PM
tpdc2
07-08-2006 02:29 PM
tommy.
11
03-26-2006 10:49 AM
Dodger2940
08-18-2002 01:06 AM
Quick Reply: motor is burning oil
