Motor Build Help!
Motor Build Help!
Hi, Im getting ready to start builiding a motor for my EK(LS bottom,GSR head), this will be my first motor build and i need a little bit of help..i was wondering what are certain things i need to do when putting the motor together/prepping it, starting for the bottom end to the top..like w/ the oil etc etc. what are just usual things you always need to do when putting the motor together? any help is greatly appreciated and sites for info will be appreciated too!thanks
Re: Motor Build Help! (xnorxcalx)
well see i was just going to put it all together and then put it in...but i think i might keep it out of the car and build...but what are some basic "for sure" things i would need to do?Also, do you know of some things i could adjust/torque when building the motor to get out a little bit more TQ/HP?thanks again
Re: Motor Build Help! (PnkRokCountryboy)
well if you're jsut putting it together then jsut go for the GE LS/vtec kit and arp or AEBs headstuds.. torque everything to spec... you should always torque to spec.. if you're rebuilding it.. you should consider higher compression pistons like b16 or ITRs.. you can use the rods and crank, new piston rings, seals, bearings, thrust washers,... oh and when you put your block together check for clearances and torque to specs..
alright thanks, yeah i planned on torquing to specs. i just think when i said it, it came out wrong..thanks anybody have anything else to say?
madrigal_x3
12-20-2010 08:08 PM
