Motor Bogs Out @ 3500-4000 RPM ????
i recently put on a shortram for a day and hooked up the stock intake afterwards...the motor just doesnt seem to wanna rev...i already tried to reset the ECU, i disconnected the neg. batt. cable and took out the underhood backup fuse but it didnt solve the problem.
anyone with some insight? thanks
Re: Motor Bogs Out @ 3500-4000 RPM ???? (axhandler)
proper way to reset the ecu:
start car & let idle for 5 minutes (turn ac & everything else off)
shut car off & remove 7.5A backup fuse let sit for 5 minutes
replace fuse & let idle for 5 minutes while the ecu learns
turn off car, start back up and drive away
go try that and see if it still bogs. i tried resetting the ecu by just doing what you originally did, and it doesn't work.
Re: Motor Bogs Out @ 3500-4000 RPM ???? (eghonda)
i had the same problem check this way. Pull your o2 plug and run around see if it still bogs. if it doesn't change the o2. -mike
