momo wheel install problem
any help is apperiated. I have installed a momo hub on a 93 civic, and after searching, a few people just not me have had the problem with the turn signals not canceling and staying on, now is thier any way to fix this or did i do something wrong. Thanks Mike
Re: momo wheel install problem (GoT HaTcH)
Thats what that round thing behind the steering wheel does. The part you shouldve taken off. It says SRS on it, thats spring loaded, it cuts off the signals.
Re: momo wheel install problem (b16eghatch)
I've done a grant wheel in my car and I have not seen the momo, but I would expect it would have to be the same. You do need to remove the airbag spool. If you have cruise, obviously it won't work unless you rewire it with some buttons on the dash or something. The little white plastic thing, on the shaft behind the spool, is the thing that turns your blinkers off. If you didn't align the tabs on the hub adapter with the slots on the blinker return, it won't work. Also, you may not have tightned the hub down far enough to get the hub to touch the blinker return. I had to put a few large washers behind the return to get it to sit close enough to the hub to work. Hope this helps.
Re: (b16eghatch)
blah.. all wrong.
I put a Momo hub on BCruz's EG not too long ago. Took off the stock steering wheel with airbag and the cable reel. Put the momo hub on. done deal.
You want to make sure you keep that white plastic peice (looks like 2 triangle ears) in the steering column, that is what actually cancels the blinkers. Then on your Momo hub, there should be peice on the back center of the hub with a slot on either end. That part slides into the white plastic peice.
You want the white plastic peice to have the "ears" pointing to the left and right.
Re: (tonyXcom)
that's weird. installed a mugen on my 92 si a long time ago, never had this problem, didn't really notice anything special at the time. (momo/mugen same thing)
ekftw
05-05-2008 07:01 PM
evolvedAP1
07-12-2006 01:22 PM
LBCek9
12-22-2005 08:40 PM
