Modding a 2000 Civic Si
Hey, i just got my em1 and now I want to put a few simple mods onto it.
I've researched cai and power chambers but I don't know which would be better, people say they're about the same but cais lag just a bit because of how long the piping is, and also that the sound from a power chamber is a finer sound opposed to a cai. I'm planning on just getting a aem v2 cai, but i'd like to get some opinions first.
I'm also planning on buying some dc ceramic headers rather than stainless steel headers... I know the stainless-steel headers would improve performance more than the ceramic, but as this car will be my daily driver, I know that the ceramic will retain heat better, so I'd also like some opinions on that.
And as far as cam-wise, I'm not too sure on what to do... itr cams, ctr cams, gsr cams, skunk 2 cams.... probably a stupid question but still curious.
I'm wanting to buy full ctr exhaust, but I'd like to know if it would be worth the money.
Lastly, i was thinking about a aem fuel rail, but i don't know if it's worth the purchase as well...
Thank you for reading my post and all opinions are welcomed.
-00 civic si
-00 civic si
Re: Modding a 2000 Civic Si
Welcome, what color is it?
Go with an Ebay 3" short ram intake with a blox velocity stack and a K&N filter. you will spend approx. $100 and will WAY outperform anything else i've seen short of ITB's. If you don't believe me, check this for yourself.
https://honda-tech.com/forums/acura-integra-type-r-8/bpi-velocity-stack-comparative-dyno-thread-2231492/
What are your longterm goals with the car? If you aren't sure i'd hold off yet on buying an expensive header. Or if you do buy a hytech replica header they are around $300 and are an excellent performing header, i've seen big power gains.
The above two questions also hinge on what your long term goals are really, i'd just hate to see you waste alot of money on things now that you will basically be doing away with if you decide to go a different route, it happens anyway sometimes but planning is important when you have a car that is a project to any extent.
This is a waste of money as far as performance goes, it's basically just an engine dress up part unless you are making serious power and have a serious fuel system that requires a higher flowing fuel rail.
-00 civic si
-00 civic si
-00 civic si
-00 civic si
If you live in an area with minimal rain get a full CAI otherwise get a short ram...
The DC header is not a quality piece, has the potential to rust and won't provide worthwhile gains... Save your money up for a good header, it is one of the more worthwhile mods you can do to your car... The material of the header has little effect on the actual performance...
Why the hell do you want a CTR exhaust and not just go with a nice aftermarket system, there are plenty to choose from... Sounds like you have been keying in on too many Honda buzzwords...
I recommend the skunk2 stage 1 cams because they provide gains above and beyond the ITR cams... GSR cams are barely an improvement over the stock cams...
Why do you want an aftermarket fuel rail? The stock fuel system will work fine for all the mods you listed...
Research Research Research my friend... It seems like you still have a lot to learn about your own car and cars in general... This is the best thing you can do right now and its free...
Next is tune tune tune, once you get into things like aftermarket cams, the car will run like garbage without a tune...
It's ebp, i plan on keeping this car as my daily-driver for a long time... I don't intend to track it as a 400+hp beast, but i do want to be able to take gsr's on the streets, not too much i'd think, but thank you for your reply...
-00 Civic Si
-00 Civic Si
-00 Civic Si
-00 Civic Si
First thing is get yourself a nice security system on that thing.....When I purchased mine that was the first thing I bought. Even though that might not keep a theif from stealing it..but it might make them think twice....Just like everyone else...I/H/E...Get some nice parts...they hold up better..
MiG-21 superfan
OP, is it safe to assume you live in cali? i am not sure of the laws out there, but i constantly hear people bitching about mods done to their daily driver and how it triggers some sort of ticketing due to CARB or something.
anyway, i suggest an intake (i like long intakes (cold air) due to the tq hump), a nice header, a true high flow cat like the ones that are available through SMSP, an exhaust without a shitty bottle neck flange where it meets the cat and some sort of tuneable ecu, either through swapping to an obd1 ecu like p30/p28 and jumper harness, or something that is a standalone like the apexi power fc (i used one of those for years and LOVED it; real time monitoring, etc)
upgrading the cams is a strong idea too, but i am not sure what's en vogue right now for otherwise stock dohc vtec.
-00 Civic Si
Now about the chipped ecu... I've been told that i should wait until I'm finished modding the engine before i put one on, as it is supposed to be one of the final additions, and I'm not too sure if i will add anything else in the future, so I'll probably hold off on that for now, but thank you very much for the info... I appreciate the response.
-00 Civic Si
before modding the SI out, but a shotgun, it is your best friend, i'd rather lose a windsheild shooting at the guy inside my car instead of losing the whole car.
Thanks, yea... for some reason I've been leaning toward a cai... don't know why lol... Yes i do live in southern cali... it is illegal to modify anything in the engine bay such as intake and headers, although my dad is a sheriff and whenever my brother had gotten pulled over the seemed to let him off the hook so I'm not really trippin... as far ticketing, I believe all they'll do is give me a fix-it ticket, so not a big deal assuming i even get a ticket...
-00 Civic Si
-00 Civic Si
street tune it temporarily to get you around.......when you get all your mods, you may wanna do a dyno tune to see where you are at and have a good *** tune with it........
get a chipped ecu.....and find someone that is a good street tuner.....when you start puttint the mods, you are currently running a STOCK ecu( meaning it is programmed to run a COMPLETELY stock b16a2)..the mods start messing up ur timing, wasting more gas, etc... if each mod u do a lil street tune, your car will run harder but blow with the extra mods your adding...
Appreciate the info, thanks.
-00 Civic Si
do it right the first time and dont go cheap. figure out what your plans/goals are and do alot of research. decide if you want to be NA or boosted. there are pros and cons that come with both.
buy everything you need and then install it all at one time and make sure you get tuned properly-hondata s300-the first time. always keep in mind that this kind of thing is not inexpensive. you have to pay to play.
goodluck.
goodluck.
get an alarm, make sure the car is running properly. when i got my SI the first mods i did to the car were out of necessity like a clutch, then rotors, pads, steel braided brake lines. every problem was an excuse to upgrade. keep it clean and safe from thieves.
Crazy Honda Guy
I'm not sure what the laws of modding are like in Cali, but here's my opinion.....
Don't waste your time with the usual CAI, and question as to wether you really want a header. The intake has obvious risks with water, and can be anoying on throttle...it only makes like 5hp. The header looks nice and saves some weight, but don't expect it to make power on a B16A, average power made in test have shown a zero to one hp gain.
Now, how to actually "make" some power, get what you pay for!! Find yourself a B18C short block. The hp and tq will be well worth the gains.
Also, consider a quality brand, camshaft upgrade, once again, good power can be made with these!
Some things to think about
I have an EM1 as well and have a short ram intake on mine. I'm actually looking for someone to trade the stock air box system for as I want to take mine back to stock. If you are interested in a trade let me know.
yeah me too, wish i would have bought a spoon direct pipe and a drop-in filter.
goodluck.
goodluck.
thank you for the help.
-00 Civic Si
-00 Civic Si
