misfire problem code 73
i tryed to change the injectors around still 73 is reading i check for pulse in wires pulse is good i tried running new wires still having problem maybe main relay???? let me know what you think its a 99 honda civic ex let me know thanks
Re: misfire problem code 73 (Luserkid)
yea new dizzy hole thing new wires and plugs tryed everything that i could think of i was thinking either computer is messed up the main relay let me know im all out of ideas???? thanks tho
Re: misfire problem code 73 (TYPErCRX)
Try cleaning out your EGR. I know it dosen't sound like anything that would be relevant to your problem, but just trust me and check it out. You may also want to get your combustion chambers cleaned out. It could also be caused by built up carbon deposits on your valves and stuff.
Re: misfire problem code 73 (coquitlamEG)
i looked for the egr valve and then i read up on it this car doesn't have one but listen to this i put a voltage meter to each injector and im getting either 1 or 1.5 or sometimes 2.2 now on injector 3 i barely get a 1! now i tested eachone at the ecu side and im getting 1 on all the injector wires accept for number 3 (blue wire) i get like a .3/.5/.7 around their now i was thinking this may be a ecu problem let me know what you think on that im going to try a different ecu if i cant find a obd2 p2p ecu i think it is??? let me know thanks
CrxSiRyder
03-29-2004 04:54 PM
