a mio parere ...
H-T White Ops
Re: a mio parere ... (teojdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teojdm »</TD></TR><TR><TD CLASS="quote">grazie mille per aver chiuso il mio topic della eg20 ... saluti e a mai piu' rivederci .... chiudo </TD></TR></TABLE>
Direct translation from Altavista, because I don't speak or read Italian.
to my opinion...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teojdm »</TD></TR><TR><TD CLASS="quote">thanks thousands in order to have closed mine topic of eg20... the salutes and never piu' see again to us.... I close</TD></TR></TABLE>
So you're mad that your thread got locked and you're never coming back again...
to my opinion...
Re: a mio parere ... (NOFX)
he was not running OEM mounts in his k swap, you can clearly see the aftermarket mounts...........why would you guys think he was running oem mounts?
yes the actual block mount and transmisson stud are oem, but they do not cuase vibration, the hybrid/hasport mounts are sloid aluminum with poly insets at th e joints to prevent alumnum rub/aluminum oxide rubbing against it self creating a fall point
means the aftermarket mounts were his problem
Re: a mio parere ... (ninethree-civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninethree-civic »</TD></TR><TR><TD CLASS="quote">he was not running OEM mounts in his k swap, you can clearly see the aftermarket mounts...........why would you guys think he was running oem mounts?
means the aftermarket mounts were his problem </TD></TR></TABLE>
HUH!?
HUH!?
89civich22
10-17-2005 05:18 PM
