Minime completed! EXCEPT...CAR wont start! Video inside Help!
i just got the head on and everything, but the car wont start, what do you think the problem is? it wont turn over at all
here is the video:
http://www.we-todd-did-racing....DE%3D
it has a minime y8 on a y7 block with a p2p ecu wired up to the stock harness with all wiring done
here is the video:
Re: Minime completed! EXCEPT...CAR wont start! Video inside Help! (Civiclx)
please help, it makes the trademark honda whine (chu chu chu) before it starts then it wont do anything after that
sorry its the wrong link, but basically it is making the starting sound but hte ignition never kicks in, do you think it could be the ignition coil or the ecu?
Re: (EG2 SiR)
check basics!! spark... fuel...
so you say there is no spark? is there fuel? unplug fuel return hose (out of the fuel pressure regulator)... hold a rag behind, and have a friend turn the key from 1-2, 1-2... let us know if there is fuel...
i had the same problem... there was spark, and fuel came out... still didn't start...
try... main relay!! (mine started up after main relay was changed)
Re: (Civiclx)
its prob. your ground i had the some prob. i took off my grounds an went with 4g wire an it kicks ***. Its the little things you do that counts when it comes to swaps
Re: (Civiclx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civiclx »</TD></TR><TR><TD CLASS="quote">there is fuel and the main relay is fine, it starts up now but screeches to hell and dies</TD></TR></TABLE>
How's the tension of your alternator belt? Sounds loose to me.
Re: (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">WTF this thread is over 6 mos old his car is working fine now!</TD></TR></TABLE>
Yeah! WTF!?!?! I didn't even notice that.
teg your it
08-23-2010 03:01 PM
aaabha
07-15-2010 01:17 PM
