mini me swap timing
mini me swap timing
ok im doing a mini me swap with a zc bottom end and a z6 top.i have the z6 timing belt with aem adjustable cams and im using a d15b7 dizzy. i put the cams and the camshaft on the tdc but it still wont crank.i need help. ps would it turn on if the vtec solenoid is not hooked up yet
Re: mini me swap timing (supaf1y)
I did a mini me swap and with cylinder #1 at TDC, i had to advance the timing like 2 or 3 teeth....someone correct me if im wrong.
yes the car will run without vtec solenoid hooked up. Is #1 at TDC?
