mini me swap ecu question
Re: mini me swap ecu question
you could use it but the speed sensor would feed your ecu another type of signal and that will create a deadly combination murder to your engine or tranny. if you have a b series swap. the car would run completely fine with a p06 5 speed ecu. i should know i had my p06 running a b18b1 for a while and no problems
Now HE has a 5 Speed tranny and wants to use a AUTO ECM the pins for the Shift of the Trans are not even found in a 5 Speed wire harness (at leat not in my car) and the Speed sensor is the same part Number (at least for my car)
so in general i would say YES it will be fine.
Now if he has some Odd setup where he had a Auto Body harnness and a 5 Speed Motor Harnness and wanted to use an auto ECM then i would have to say keep a Fire extinguisher close by cuz the backup light switch uses the same pins on the Motor harness as the auto trans body harness use for the shift switches and that could be Very Bad.
mengy007
05-21-2006 05:26 PM
asocallocal
07-21-2005 07:20 PM
d15bcrex
01-15-2004 09:27 PM
