Mini-Me Swap on an Automatic?
i want to do the swap but i'm concerned about 2 things
1. Its a D16Y7 and the Y8 Head, would the automatic still be able to function correctly? will it adapt its shift points or what? what about when Vtec Engages?
2. How much would this swap affect MPG?
Re: Mini-Me Swap on an Automatic?
not 100% sure but ive done some reading up on this. your automatic will be fine you have to swap ecu's so it will shift when the y8 does. and i would assume your gas mileage would be what a y8's is.
yep you we golden, you going to have to swap a y8 ecu in so that it run, doing that it will think its a y8 motor and tranny, and it will shift where the y8 motor is supposed to shift.
im planning the same thing,
it might be higher or lower I dont know, cause your using a dx or lx block and ex head, so you might get dx millage or ex, or somewhere in the middle. maybe higher.
I just got done doing this and I have to say the above information is incorrect. The P2P ECU out of the Y8 will not work correctly with the Y7 tranny. You will need to run the P2E ECU with a VTEC Controller. I found out the hard way.
Seagull Management
And how exactly do you figure that? Considering that so far as I can tell Y8 automatics use the same transmission as the Y7s (B4RA, or S4RA depending on the year) So long as you use an automatic P2P ECU you should be perfectly fine, and like the guy above me said the vtec controller is absolutely useless. You need a vtec ECU to actually change the fuel and timing maps for vtec to actually do anything other than sound like vtec.
Seagull Management
My guess is you used a 5 speed P2P ECU, if you can post the numbers on the side of the ECUs you tried this will tell me for sure one way or the other.
The numbers are,
37820-P2P-A71
272-102270
37820-P2P-A82
273-205890
Which number identifies if it is auto or manual? I know that 37820 is just Honda's ECU part number and the P2P is all 96-00 EX but beyond that I'm unsure.
Seagull Management
I've bolded the important numbers
The A in front of the bolded number designates the country code, in this case US, the next digit (the bolded one determines if the ECU is auto or manual, 5,7,9 is usually automatic, 0 and 1 are 5 speed. I've never seen or heard tell of 8 before though.
slikz714
10
06-16-2007 04:59 PM
