mini me question
mini me question
Hey this is my 1st post so hi.
I have been toying with the thought of doing a mini-me set up with me 1995 CX HB. Does anyone know all of the components i will need to get?? Also does anyone have any guides or resources i can look at to see what i am getting into. Any help is greatly appreciated. I beleive my stock engine is D15B but i am not 100% sure on it. Too cold to check now.
Thanks alot guys
Thanks alot guys
Re: mini me question (XoUnKoWnXo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XoUnKoWnXo »</TD></TR><TR><TD CLASS="quote">Hey this is my 1st post so hi.
Thanks alot guys</TD></TR></TABLE>
VTEC head
VTEC ECU
Re wire for a VTEC IACV
Wire in the VTEC soleniod
wire in the VTEC pressure switch
VTEC head
VTEC ECU
Re: mini me question (infinatenexus)
how much does this swap cost ballpark?? And also where do you think the best place to get the head and ecu from? online or do you think a junkyard would be best??
Risky Business
<FONT SIZE="5">THE MOTHER OF ALL MINI ME THREADS:</FONT>
https://honda-tech.com/zerothread?id=554053
Re: mini me question (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote"><FONT SIZE="15">THE MOTHER OF ALL MINI ME THREADS:</FONT>
The mini me master has returned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XoUnKoWnXo »</TD></TR><TR><TD CLASS="quote">i did read that very informative thanks. I was just looking for other stuff on it.</TD></TR></TABLE>
what do you need to know
the cx is a 8valve head and the earlier model's pistons only have indents for 8 valves on them instead of 16. i believe that some of the 94s and on had the 16 vavle pistons already installed. you should be able to do the complete swap for about 250-400 depending on how good you are at searching for parts(little **** will add up)......... or if you are lucky you might be able to save up a little extra money and search around and find a complete d16z6 swap with tranny because the gearing is way better than your cx. plus the d16 has a little broader market for internals if you were to build it for boost or whatever. good luck
Risky Business
Re: mini me question (lohatch)
^VERY good point. I should add that the CX transmission is complete garbage (I stated this in my thread) and that your car will probably still be slower than a DX with the mini-me. Either get both the Z6 head and transmission or get the whole swap...regardless of what you you'll still be slow if you keep that tranny on. Good luck.
Risky Business
Re: mini me question (Taffeta_EXcpe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Taffeta_EXcpe »</TD></TR><TR><TD CLASS="quote"> https://honda-tech.com/zerothread?id=554053
Uhhhhh...
Uhhhhh...
orangeracer
03-28-2008 07:08 PM
Ran4it2
10
11-23-2007 09:46 AM
