mini me.......no spark???????
okay..just got done with a second mini me...first one went kabooomm...now just finish the second one....everything done and i went to start it up. the motor cranks buts its getting no spark...check the distributor..seems fine...what could it be..help please...
Re: mini me.......no spark??????? (sohc_vtec)
how did you check the distributor? Got everything wired up correctly?
Re: mini me.......no spark??????? (ABK)
Are you getting spark at the plugs? If not start at the plugs and work your way back until you've got spark.
Re: mini me.......no spark??????? (Ricey McRicerton)
When you put back the ignition wires did you install them correctly? (Correct order)
Re: mini me.......no spark??????? (94JDMEG)
test the coil pack
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABK »</TD></TR><TR><TD CLASS="quote">how did you check the distributor? Got everything wired up correctly?</TD></TR></TABLE>
opended it up, took everything apart...look at it closely...everything seems fine..yeah..im pretty sure everythings wired up right because im using a y8 head nad its obd2 on an obd2 car..yeah im positive its wired up right.. |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">Are you getting spark at the plugs? If not start at the plugs and work your way back until you've got spark.</TD></TR></TABLE>
nope no sparks at the plugs..got new plugs for it...still no sparks at the plugs.. |
Re: mini me.......no spark??????? (slow90hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow90hatch »</TD></TR><TR><TD CLASS="quote">test the coil pack</TD></TR></TABLE>
no more coil pack...im using a accel ignition... |
im thinking its the ignitor thats dead...maybe thats the problem..you guys think it might be the ignitor..
I seem to be facing the same problem, the motor cranks but still it doesn't start, so what i did i checked the distributor if it had spark by taking 1 of the wires off the distributor and putting a screw driver where the the wire goes and i had some1 crank the motor while i held the screwdriver to see if it sparked ma hand but it did'nt so i guess is the ignitor or the whole dizzy just shot, if anyone got an idea to help let us know!!!
why don't you buy yourself a digital voltmeter and find out. It's as easy as that. One of the best tools you can have.
can i change out my old y8 ignitor for a dx ignitor..will it still work the same or is a different ignitor..
same, try it
Re: mini me.......no spark??????? (yanta)
okay...i got it to work now...got spark..it was the rotor... http://images.honda-tech.com/set1//smile/emcrook.gif ....now its giving cel code 3 and 5..something with the map sensor..i switched it with a dx map sensor and did the same thing..the car runs like ass..now running on limp mode...need help guys..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABK »</TD></TR><TR><TD CLASS="quote">how did you check the distributor? Got everything wired up correctly?</TD></TR></TABLE> Id start there if were you..
Re: mini me.......no spark??????? (PowerShot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PowerShot »</TD></TR><TR><TD CLASS="quote"> Id start there if were you..</TD></TR></TABLE>
so your thinking that its the dizzy thats throwing me into limp mode...and caused the cels... |
okay...still in limp mode...took off throttle body and cleaned the living hell out of it and it still giving me cel 3 and 5...this is killing me yo..help me out..
ttt
