MINI ME...HELP...
MINI ME...HELP...
okay..just got done with my mini me swap..the only problem was the timing belt...the setup is a y8 head on a d15b8 block...i used a y8 belt but after the install there was too much slack in it..not tight...i was confused..i was told to used a z6 belt or a vx belt..help me out...search and didnt find nothing..
New User
Re: MINI ME...HELP... (sohc_vtec)
Use search, BaileyCivic wrote a whole article explaining everything for the mini-me conversion. It covers the timing belt and ****. Let me know if that doesn't help!
Search: "Mini-me"
Search: "Mini-me"
Re: MINI ME...HELP... (976)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 976 »</TD></TR><TR><TD CLASS="quote">Use search, BaileyCivic wrote a whole article explaining everything for the mini-me conversion. It covers the timing belt and ****. Let me know if that doesn't help!
Search: "Mini-me"</TD></TR></TABLE>
already did..didnt really help..searched before i posted..
New User
I searched and found your answer. You need the Z6 timing belt...
https://honda-tech.com/zerothread?id=554053
New User
Yeah, no problem.
It makes sense, the head changes the location of the cam gear, the block stays the same, therefore the timing belt would need to match the head.
New User
Re: MINI ME...HELP... (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">I thought the Z6 and Y8 belts were the same?</TD></TR></TABLE>
So you didn't do the write-up?
Risky Business
So you didn't do the write-up? </TD></TR></TABLE>
No i'm just wondering why the Y8 belt didn't work and the Z6 did work.
the z6 and y8 have the same number of teeth, but the y8 is about a 1/4 inch longer than the z6. therefore it will have more slack. unless you forgot to reset the tensioner when you put it on, which will cause slack either way.
New User
Re: (spooncivic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spooncivic1 »</TD></TR><TR><TD CLASS="quote">the z6 and y8 have the same number of teeth, but the y8 is about a 1/4 inch longer than the z6. therefore it will have more slack. unless you forgot to reset the tensioner when you put it on, which will cause slack either way.</TD></TR></TABLE>
Ah, good info...
Ah, good info...
Ser1N
03-08-2006 01:54 PM
julio_bOostamante
09-21-2005 07:59 PM
*Boostwerks*
06-25-2005 11:17 PM
