middle vents on civic a/c wont blow
Old 05-19-2004, 03:55 PM
New User
mafioso102's Avatar
Default middle vents on civic a/c wont blow
its a 96 civic ex, for some reason the middle two vents will not blow out any air...the outer two are fine. any suggestions? Thanks
Old 05-19-2004, 08:19 PM
New User
mafioso102's Avatar
Default Re: middle vents on civic a/c wont blow (mafioso102)
bump
Old 05-19-2004, 09:25 PM
95civicSirCoupe's Avatar
try putting it on recycle air instead of freash outside air. i know it might sound dumb but i had that same problem but when i switched it to vent and recycle it came out. dont ask me why. check freon too.
Old 05-20-2004, 11:11 AM
New User
mafioso102's Avatar
Default Re: middle vents on civic a/c wont blow (95civicSirCoupe)
tried...and its not that cold air isnt blowing, its that NO air is blowing...is there a fan that services the middle vent only?
Old 05-23-2004, 08:55 AM
New User
mafioso102's Avatar
anyone?
Old 05-23-2004, 10:03 AM
H-T White Ops
Frozen E's Avatar
time to go digging around under your dash. A duct popped off or something. I've had the same problem in my old lude. But with that one it was the driver's side vent that wasn't blowing. It should just be a black plastic dusct that popped off if all of the sudden you're not getting any air flow.
Old 05-23-2004, 11:17 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mafioso102 &raquo;</TD></TR><TR><TD CLASS="quote">tried...and its not that cold air isnt blowing, its that NO air is blowing...is there a fan that services the middle vent only?</TD></TR></TABLE>
There is only one fan. Have you checked the mode control motor? Does it move at all?
Old 05-23-2004, 11:24 AM
jcarothers's Avatar
I'm willing to bet a harness isn't connected somwhere. the same thing used to happen in my car, I'm not sure how it works in later civic's but in mine there were two harness connections on the hvac and one wasn't connected.
your problem sounds dead on like mine did, so it may be worth a look. goodluck.
Old 05-23-2004, 12:49 PM
Ej1_coupe's Avatar
Default Re: (jcarothers)
is the vent closed?
Old 05-23-2004, 12:59 PM
menkio's Avatar
Default Re: (Ej1_coupe)
heatercore might have died, i'm selling mine.. 35 its yours
Old 05-23-2004, 01:09 PM
yusoslo's Avatar
Default Re: (DewMota)
yeah have you messed with the vent slide????
that may be a simple yet plausible problem
Old 05-23-2004, 02:20 PM
H-T White Ops
Frozen E's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DewMota &raquo;</TD></TR><TR><TD CLASS="quote">heatercore might have died, i'm selling mine.. 35 its yours</TD></TR></TABLE>
What's that have to do with anything? His other vents work. Just the middle two don't. He didn't say his heat doesn't work.
Old 05-23-2004, 02:34 PM
BlownVR's Avatar
Default Re: (IslandSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi &raquo;</TD></TR><TR><TD CLASS="quote">time to go digging around under your dash. A duct popped off or something. I've had the same problem in my old lude. But with that one it was the driver's side vent that wasn't blowing. It should just be a black plastic dusct that popped off if all of the sudden you're not getting any air flow.</TD></TR></TABLE>
i think the same thing
Old 05-24-2004, 01:54 PM
New User
mafioso102's Avatar
Default Re: (CivicVXHatch)
thanks for all the responses, im gonna check it out!
Lithel
10-03-2023 12:51 AM
Pwnmeister
15
09-27-2011 08:13 AM
alscrx
10
01-03-2008 06:57 PM
TekNinja23
07-11-2003 08:26 AM
Quick Reply: middle vents on civic a/c wont blow
