metal shavings on valves
Old 02-07-2005, 06:14 PM
vxnine's Avatar
Default metal shavings on valves
ok i used ezout drill bits on my valve cover bolts because the bolts snapped and i had to get them off somehow. so when i did that i got some metal shavings under the valve cover and i saw some on a valve spring. so what i did was got a q-tip and cleaned what i saw.. are metal shavings potentially dangerous? they are very very small and feel like soft wood shavings, they arent all hard or anything. would this ruin my head or anything. any help is appreciated. thanks
Old 02-07-2005, 07:21 PM
vxnine's Avatar
Default Re: metal shavings on valves (frankcivic)
bump for help
Old 02-07-2005, 07:25 PM
jlacoy82's Avatar
Ummmm, they could make their way down the oil passages and through the pump and everywhere else in the motor, not quite sure what they might damage though. I'd say theres a possibility for damage, but not sure how much.
Old 02-07-2005, 07:26 PM
civictildeath's Avatar
if any are left they could block oil passages or get in between the pistons and the clylinder wall and scratch it to hell and back.
or could fall to the bottom and stay there and never hurt a thing.
Old 02-07-2005, 08:12 PM
jeffk182's Avatar
Try using a magnet to pick up some of the shavings.
95_teggygsr
01-25-2009 11:16 AM
Timmyflys
07-22-2007 03:21 PM
teg your it
05-22-2006 07:59 PM
yeegsr
12-13-2004 07:32 AM
drjondurst
11
06-07-2003 11:15 AM
Quick Reply: metal shavings on valves
